rear passenger exit?
Old Nov 23, 2009 | 03:31 AM
unleashedd's Avatar
well, im sure all u noticed that the front doors have a tendency to close themselves. yesterday, me and my copilot get out and completely forget to let the two people in the back out. is there an easy way for the people sitting in the back to open the doors? im assuming theres no trick involved, but it wouldnt surprised me if Mazda thought of this as well :D
so, can they get out on their own?
Old Nov 23, 2009 | 03:39 AM
Twiztog43's Avatar
i dont think so, i mean i have tried it and its pretty difficult getting the front door open from the back seat and opening the back door at the same time.
Old Nov 23, 2009 | 04:02 AM
c0ldf1ame's Avatar
its always a puzzle
Old Nov 23, 2009 | 04:06 AM
g0rdhan's Avatar
agree with flame, the puzzle makes it fun!!
Old Nov 23, 2009 | 07:57 AM
unleashedd's Avatar
oh cmon if ure trying to make me get stuck in the back seat... well u prolly succeeded, i wont sleep until i figure this out
Old Nov 23, 2009 | 08:19 AM
JinDesu's Avatar
went back to srsly broke
Passenger side can reach for the seat reclining handle and push the seat down to reach the door handle. Driver side is pretty screwed
Old Nov 23, 2009 | 12:26 PM
zoom44's Avatar
rear passenger just grabs the black web tab at the bottom back of the front seat to tilt it forward. then opens the front door and then the back. alternately if they are small enough-i can do it- they can just crawl into the front seat from the back and get out that way.
also if the pass thru is unlocked they could open the pass through get into the trunk and open it with the emergency handle and climb out
Old Nov 23, 2009 | 12:29 PM
Twiztog43's Avatar
^not if theyre pretty chunky
Old Nov 23, 2009 | 12:33 PM
EMart11b's Avatar
Bang Bang
I have a button on the back of my driver's seat, for God knows what reason, that moves the seat and back forward. The annoying thing is it works whenever the speedo reads 0 so at a stop light someone in the backseat can push me up against the steering wheel... Stupid button, I'm considering disconnecting it.
Old Nov 23, 2009 | 12:37 PM
CyberPitz's Avatar
Huge hole is huge
Just use your super reach.
Old Nov 23, 2009 | 12:39 PM
sanyok's Avatar
wont work if you have the spare either
Old Nov 23, 2009 | 01:17 PM
911SC's Avatar
Copilot? I didn't realise it took two people to drive this thing!
Old Nov 23, 2009 | 02:24 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Here yah go. Combo glass breakage and seatbelt cutting device.
Old Nov 23, 2009 | 03:13 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
^ lol i dont think he want to damage his ride! but i have one of those just i case!
Old Nov 23, 2009 | 03:25 PM
JinDesu's Avatar
First time I ever saw that button, now I need to check mine and hope to god I don't have that button
OP, the front doors have certain angles where if you exceed it, they will stay open. Granted, those angles are huuuuge, but they will stay open
Old Nov 23, 2009 | 07:28 PM
Glitched's Avatar
The button is an 09 and up feature... possibly only on GT... not sure. Like seat memory..
*grumbles about buying the last 08 on the lot in March and missing out on the new features*
Old Nov 23, 2009 | 10:52 PM
If I carried a lot of passengers in the rear, I'd get one. Also if I drove by a lot of water, I'd get one too. I've seen from multiple tests on TV that the sooner you get out of a car that goes into water the better. But none of those apply for me.
Old Nov 23, 2009 | 11:09 PM
1.3L's Avatar
1. Scream
2. Bash out windows
3. Scream
4. Call 911
5. Squeeze between front seat backs, drive away while gesturing to owner.
Old Nov 25, 2009 | 04:20 PM
New Yorker's Avatar
Okay, the problem isn't that rear passengers can't exit. As others have noted, the guest on the passenger side can get out fairly easily; the one sitting behind the driver can exit with a bit more difficulty.
No, the real issue is that knowing how to get out IS NOT INTUITIVE. Consider showing rear passengers "how to exit" when you're about to leave them in the car—much like a good motorcyclist tells his/her passenger to lean into turns and not touch the exhaust pipe.
Old Nov 25, 2009 | 04:25 PM
hakuna matata!
lol.
Old Nov 25, 2009 | 05:17 PM
c0ldf1ame's Avatar
i put in a roll bar so i no longer have rear passengers, problem solved
Old Nov 25, 2009 | 05:31 PM
DarkLord7854's Avatar
Software Engineer
Make em go through the sunroof.
Old Nov 25, 2009 | 11:14 PM
JinDesu's Avatar
But that's true for 2+2 coupes as well, it's not something that only happens for the 8.
Old Nov 25, 2009 | 11:22 PM
RyansRx8's Avatar
Brettward is/has a G
When you get out, leave your door open and then open the back door...If your not a gentleman then they can reach the handle for the back door its right there lol
Paul_Y
Sep 21, 2015 02:23 PM
vapor2
Sep 19, 2015 05:33 PM
CMRine04
Sep 17, 2015 10:04 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
mitchrx8
Sep 13, 2015 08:05 AM
