Warning Buzzer
Old Nov 16, 2009 | 12:40 PM
renesisgenesis's Avatar
mod edit
Warning Buzzer
does anyone know at what rpm the warning buzzer activates on an MT? I would guess about 8150 or so.
Old Nov 16, 2009 | 12:44 PM
mscamp02's Avatar
Blue Bullet?
somewhere between 8 and 9k yeah....but I have to ask why does it matter at all?
Old Nov 16, 2009 | 12:48 PM
mod edit
well it doesn't really matter but then again nothing on these forums really matters. I just am curious and want to know as much as i can about my car.
Old Nov 16, 2009 | 12:49 PM
8,500 rpm
dillsrotary's Avatar
jersey fresh
Old Nov 16, 2009 | 12:52 PM
mod edit
Originally Posted by dillsrotary
That's a weird response. Obviously the answer to the question is that I care; which explains why I asked the question. Trying to be clever with a rhetorical question doesn't work when there is actually an obvious real answer.
Old Nov 16, 2009 | 01:06 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Warning buzzer = big smile!
dozer's Avatar
on his 3rd rx8
8500 rpms
Old Nov 16, 2009 | 01:23 PM
mod edit
I am assuming the 8500 responses are jokes...right.
Obviously i am asking because the tach is considerably innacurate, so i cant just look at it while driving to determine this. So i was just curois if anyone knew what the actual rpm was where it activates. According to the tach, it starts at about 8400 or so, because the leading edge of the needle only needs to reach the 8500 mark, not the center of it for the buzzer to go off. I would guess this is around 8100 to 8200 in reality but not sure.
Old Nov 16, 2009 | 01:24 PM
dozer's Avatar
on his 3rd rx8
go outside and try it...then come back and tell us
Old Nov 16, 2009 | 01:25 PM
The Reverend's Avatar
That's a lie
lol
Old Nov 16, 2009 | 01:27 PM
mod edit
I don't understand? try what?
Old Nov 16, 2009 | 01:29 PM
RIWWP's Avatar
I'm mildly curious why you can't just drive it and when it goes off, look down and see? Sure, the tach isn't precisely accurate, and up there is off by a few hundred rpm, so subtract a few hundred from what you see, and your pretty darn close.
I used that method, and it worked great for me.
Old Nov 16, 2009 | 01:36 PM
since people did in fact attempt to answer your question, the only reponse I can give you now is:
R.T.F.M. !!!!
Old Nov 16, 2009 | 01:37 PM
Huey52's Avatar
Registered Zoom Zoomer
8,500 rpm; but since my MazdaSpeed RX-8 GT exceeds the speed of sound at this rpm range I don't actually hear the beep until 9,000 rpm.
Old Nov 16, 2009 | 01:46 PM
josuar88's Avatar
The Crawlster
Go out to you car turn in on and rev it slowly up to 9000rpms you should hear it when the needle hits the red/black section of the rpm gage.
jersey fresh
You reply trying to return an intelligent answer, but cannot simply google the answer yourself?
google this: what rpm does the rx8 beep
The first 30 results have the answer.
Sounds like you just enjoy typing.
I look forward to your next thread "what color is my car?"
Old Nov 16, 2009 | 01:56 PM
mod edit
Well considering everything there states the same, obviously incorrect 8500, I figured it would be wise to ask the geniuses here for some more accurate advice. Instead you point me back again towards the same problem that I mentioned in the original post: The f'ing tach is off so obviously i can't just look...hence the creation of thread.
omg nevermind.
Me: "the tach is off, so i was just curious what a particular point of interest is in terms of actual rpm if anyone has accurate data"
replies: "look at the tach" or, even better, "look at internet sources that just tell you what the tach says"
Old Nov 16, 2009 | 01:59 PM
RIWWP's Avatar
How about this. If you already knew that A: the tach was off, and B: the conventional reply is going to be what the tach shows, then why didn't you ask (or search for) how far off the tach was? It would give the the means to answer your own question without sounding like a complete moron?
As it is....
Old Nov 16, 2009 | 02:01 PM
Transam kid 01's Avatar
The anti-ricer
Buy an accessport and find out...or wait till I play with mine later tonight
Old Nov 16, 2009 | 02:03 PM
Gr8Bullet's Avatar
Or just use a scanning device that reads live info. An AP should work just fine.
Old Nov 16, 2009 | 02:15 PM
you guys are asking the guy who doesn't believe in mods to buy an AP? good luck.
Old Nov 16, 2009 | 02:17 PM
RIWWP's Avatar
Doesn't believe in mods? You mean like...brain mods? Driver mods? You can't be referring to car mods. No, don't believe that.
Old Nov 16, 2009 | 02:23 PM
Gr8Bullet's Avatar
What is this non sence your speaking of Jedi!! You have the power to change his thoughts with the wave of your hand about mods!
Old Nov 16, 2009 | 02:28 PM
CyberPitz's Avatar
Huge hole is huge
Agreed with everybody else on a "Get the AccessPort to get a real reading"
