Idle and Recall Questions
Old Nov 12, 2009 | 09:05 PM
tcmers's Avatar
I just bought an 04 RX-8 MT with 40,000 miles. A couple of times when sitting at a stoplight the idle has suddenly dropped to around 500 rpm, surged up to 1200-1300, then drops back to normal. It's only been a coule of times and each time the car has been stopped, in first gear with the clutch depressed. Most of the time it idles smoothly. Any idea what might be going on?
Another question.... I'm taking the car in for service next week. I asked the dealer to check for open recals on my VIN. The service guy told me there was one related to the flooding issue that would take about 45 minutes to do. Some type of reprogramming? Any other recalls I should ask about? Vacuum test? Thanks!
Old Nov 12, 2009 | 10:08 PM
Old Rotor's Avatar
The idle should not do that. It could be over due for spark plugs(37K miles). I did my plugs, coils,wires for about $250 with my son in an hour(dealer will charge about $700). It could also be a simple cleaning of the MAF sensor. Or a couple of cans of de-carbon cleaner(Seafoam or BG44K) might improve compression. This is just a start look at the bottom of the page for some more ideas.
Old Nov 12, 2009 | 11:46 PM
if your spark plugs, coils, wires are "up to date", gas is good, MAF is clean
then I will start looking at throttle body and ... engine
Old Nov 14, 2009 | 07:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
like mentioned above..change plugs/coils if it's been awhile....
Old Nov 16, 2009 | 07:48 AM
tcmers's Avatar
Thanks! I would guess that the plugs are original. I'll get plugs & coils on order. I've looked through the DIY sections and it looks like a fairly straight forward job.
Old Nov 16, 2009 | 08:17 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
This isn't at the OP........but when the hell did everyone start going 35k+ miles on a set of plugs!
I rarely if ever let them get much over 10k on ANY car I have ever owned!!!!!
OP.....sounds like it's time for coils, plugs, and wires!!!!
Old Nov 16, 2009 | 08:55 AM
tcmers's Avatar
Can anyone give me a good source for coils & wires other than the dealer? I know I can get plugs online, but haven't found the other parts. Thanks!
Old Nov 16, 2009 | 09:39 AM
Well, for piston engine, 30K plugs are ok.
but for Rotary ... 15K the most.
Thats just me tho
www.onlinemazdaparts.com
www.finishlineperformance.com
or just contact BHR.
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
