Hazard Light Switch - reattach to Head Unit
Old Nov 8, 2009 | 08:40 PM
yinzerR8's Avatar
New to the forums, I've been able to find everything I needed to do the simple stuff - change plugs, install DICE iPod converter, fix the broken heat switch & oil - I am having the hardest time finding where the HAZARD LIGHT SWITCH plugs into the freaking head unit.
As far as I can tell this '04 had an aftermarket headunit installed, and previous dude slapped the old one in prior to getting rid of it (the radio didn't work due to the antenna being loose - but neither did the heat . . .)
In any event I've looked all through the head unit, and I can't figure out where the 4 pin cable coming from the hazard light goes - I've attached a couple low rez pictures where you can see the extension cable.
Any help? I feel that this is wicked simple & I'm looking past it
Attached Thumbnails Hazard Light Switch - reattach to Head Unit-1020092257.jpg   Hazard Light Switch - reattach to Head Unit-1020092257a.jpg
Old Nov 8, 2009 | 08:53 PM
ZumnRx8's Avatar
RX8 & RX7 owner
http://www.whatsmyip.org/ipodrx8/
Old Nov 8, 2009 | 08:56 PM
ZumnRx8's Avatar
RX8 & RX7 owner
i had a metra kit also... but dont remember on the OEM stereo........ ill try searching a little later...look up on the METRA KIT MANUAL it should be in it...its available online
Old Nov 9, 2009 | 09:48 PM
yinzerR8's Avatar
Thanks for the quick reply - I found the link here -
http://www.sonicelectronix.com/pdf/metra/met-957510.pdf
Look familiar? I'm guessing I'm going to have to tear the dash apart again - I'll post the results
Old Nov 11, 2009 | 10:14 PM
yinzerR8's Avatar
Figured it out
Once removing the protective cover I found the cutout - at least on the 2004 oem head unit the input for it is on the front side of the board
Attached Thumbnails Hazard Light Switch - reattach to Head Unit-1111092144.jpg   Hazard Light Switch - reattach to Head Unit-1111092144a.jpg   Hazard Light Switch - reattach to Head Unit-1111092150.jpg   Hazard Light Switch - reattach to Head Unit-hazardlightarrow.jpg
Old Jul 22, 2015 | 06:01 PM
Mu56's Avatar
Hi guys could anyone please help me with what connector block and wire colours that plug into the back of the head unit are for the hazard lights as I am stripping my rx8 out for the track and have removed everything un needed like head unit and so on I would like to connect up a new switch to keep the hazards working???
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
mattymack
Sep 6, 2015 10:33 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
