Rear Differential Trouble ???
Old Nov 5, 2009 | 10:13 AM
XXXrx8XXX's Avatar
Mazda Mica Grey 2006 GT
Ok my car has 36000km on it and i noticed that when i speed up when car is still cold on the highway i feel a rumbling sound from my right back tire almost a feeling of having an over inflated tire....on top of that the tire wears a bit in the middle very slightly... when putting it in nutral on the highway it slows down instead of keeping speed for a bit
btw i use red line in my back diff changed it when the car had 12000km on it
any suggestions
Old Nov 5, 2009 | 11:34 AM
416to212's Avatar
Utopia Taco Bell
A rear diff problem at 36,000 is highly unlikely if you have been using this car strictly as a street car. I'm assuming you're not involved in a drift series and that when you replaced the diff fluid you used nothing but RedLine 75w-90. Also a poorly performing diff would be more noticable in turning situations.
The right rear tire wearing in the middle seems like it's overinflated or the rim has developed a hop. Check the pressure and adjust. If pressure is okay then run your hand on the tread pattern. If the blocks feel slightly sloped or cupped on the edges you have a rim with a hop/bend in it.
Also swap the right rear for the right front and see if any of the vibrations come from a different place.
These are simple and free trouble shooting tips (no mechanic needed). If these don't work out for you then I could offer more advice.
Old Nov 5, 2009 | 11:48 AM
renesisgenesis's Avatar
mod edit
well.....have you checked your tire pressure?
and....technically it is impossible to NOT slow down immediately when the car is not in gear...
Also I wonder if you have an automatic or a stick?
Old Nov 5, 2009 | 12:02 PM
fyrstormer's Avatar
2009 RX-8 Touring
I get the same noise. Your tires are flat-spotted from sitting overnight, and because the rubber is cold it doesn't round-out as fast as you expect it to when it's warm, so it's still not perfectly round by the time you get on the freeway.
Pump up your tires a bit; the higher the pressure, the less they will flat-spot. Also, high-performance tires are more likely to exhibit this in the first place.
Old Nov 5, 2009 | 10:03 PM
XXXrx8XXX's Avatar
Tire pressure is good and so is the rim ...Maybe it's just flat-spotted as you mentioned i use Potenza stock tires....the dealer ship said that the tires are crap and reason why loosing tread in the middle...i think its BS because its only one back right tire i had them rotated and it's doing the same thing to the rotated tire middle strip line is starting to dissapear after 5000km .......had alingment done too..... so i dunno what is up i did curb that back tire one time when car was new but it was a light hit the rim just scratched...could it be i bent something slightly??
Old Nov 7, 2009 | 01:14 PM
mlfarrell's Avatar
If your tires are stock, from what I've been told they turn to bricks under 40 degrees (f). I've definitely felt a difference during the cold months as I'm one of those ppl that never swaps out for all-seasons or snow tires. I generally don't accelerate as hard or take turns the same in winter
Old Nov 7, 2009 | 07:39 PM
fyrstormer's Avatar
2009 RX-8 Touring
As soon as I wear the stock tires out, I'm switching to Michelin Pilots and never looking back. I've had them on two other cars and they were worth every penny.
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
Steve Dallas
Sep 19, 2015 09:39 AM
