2009 Wiring Diagram
Old Nov 3, 2009 | 08:40 PM
dapunk's Avatar
2009 Wiring Diagram
Would anyone happen to have the Wiring Diagram for a 2009 Bose setup?
They changed the setup in the 09.
Trying to hook up a AudioControl 6XS crossover (Stock Deck) to Aftermarket amplifiers but the wires are different and connectors styles are different as well.. (We found the Rear Speakers easily but the Front are the issue atm)
Im guessing atm that the Fronts are directed to each door to a mini-amp (Guessing) since everything is unplugged from he Stock amp and the fronts are still working. Before I start pulling everything apart, any suggestions?
Old Nov 4, 2009 | 01:07 AM
Juice's Avatar
I made some poos
Why not take out the headunit and check the wiring colors there. Mazda has been using the same 24 pin connector for years with basically the same pin out. You can check the install sticky for what the pin outs are and where each pin is on the connector, then just check the connector in your car for the wire colors. These should be the same colors at the Bose amp since the Head unit signal goes straight back to the amp input which I assume is where you are trying to tap the signal for the 6XS.
A little extra work to pull the radio out, but you should have your answers. Also, if you do do it this way try and post what you find for future 8 owner reference.
R3Dream
Mar 7, 2019 09:11 AM
R3Dream
48
Mar 12, 2016 01:44 PM
jer2911
Sep 29, 2015 06:37 PM
