No lights flash on lock!!
Old Nov 3, 2009 | 10:09 AM
vipertek602's Avatar
Unhappy No lights flash on lock!!
Hello,
I cant seem to get the lights to flash when I lock the doors with the fob. I have a 2005 Rx8 AT which I just bought it recently and the lights never flashed since I had it but after reading several threads, I think they are supposed to.
I know what most people are going to say: "make sure that the trunk and engine lid are closed" I assure you that I have made sure that both are closed several times.
Also, my hazard lights are not working when I press the button just above the cd player. I'm not sure if they are related or not, maybe.
Any ideas?
Old Nov 3, 2009 | 10:13 AM
zoned's Avatar
rotary user
sounds like a burnt fuse to me.
Old Nov 3, 2009 | 10:24 AM
Hmm....forgot to mention that I already changed the fuse for the hazard light and it still doesn't work.
Is there another fuse for the blinking lights?
Old Nov 3, 2009 | 01:45 PM
rafaga's Avatar
Did you check the fuse box inside the cabin on the driver's side? I don't remember which circuits are there, but you might as well check those too...
Old Nov 3, 2009 | 02:11 PM
Ya, I checked the fuses inside the car but I dont think that there are any for the hazard lights. I checked them all anyways and they are all fine.
Old Nov 3, 2009 | 02:12 PM
iLikeEatPoo's Avatar
The Great Dick
Turn signals still work?
Old Nov 3, 2009 | 03:47 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
I'll see if I can dig up where it is, but with all that you've said..............it could be the flasher relay!
Old Nov 4, 2009 | 09:58 AM
Ya, the turn signals still work.
If it is the relay, then is it something I can replace myself?
Where is the relay located?
Old Nov 5, 2009 | 01:53 AM
first make sure the trunk is closed tight..
Old Nov 5, 2009 | 06:40 AM
SARRAS's Avatar
Sydney, Australia
And both rear doors - on mine it won't flash if the rear doors aren't shut properly.
Old Nov 5, 2009 | 08:18 AM
I have tried everything you guys are saying. All the doors and the trunk and hod are closed properly. I have owned the car for 6 months and the lights have never flashed on locking. Also, the hazard lights were not working when I bought the car.
Any other ideas?
Old Nov 5, 2009 | 02:56 PM
8 Maniac's Avatar
Senior Member
I had the trunk cracked open once and didnt realize it.
Old Nov 5, 2009 | 06:38 PM
Believe me, I have slammed the trunk very hard so many times!!
I dont think that is my problem.
Old Nov 5, 2009 | 06:50 PM
short the connector. just to be sure its not the sensor's fault. then see if the lights come back.
Old Nov 5, 2009 | 07:06 PM
The Great Dick
If the trunk/door/hood was open his hazards should still work.
Old Nov 5, 2009 | 07:20 PM
well then, he gotta take a multi meter and start tracing wires (if fuse/relay are ok)
Old Nov 6, 2009 | 03:55 PM
Mazurfer's Avatar
To the original poster:
Did you or have you done any moving of any cables or unplugging any connectors anywhere at anytime? Also............if you are not the original owner, do you know if there is any after market lighting in or on the car?
reasons......however far fetched.
Something happenned to me when I was changing my daughters cabin filter in her 3. To do this you must actually take the damn fuse box out(which on that car is behind the glove box)! Anyway, once I was done her alarm wouldn't arm, and therefore lights wouldn't flash either. Actually she had a door ajar light lit, even with doors closed as well, but the dorrs would lock. Come to find out that one of the connectors wasn't properly seated. I'm thinking since you hazards don't work either that this could be the cause.......and bad connector not seating properly. So...............has any work been done on the drivers side inside panel or around the center console area?
Also wondering if someone before you may have wired something wrong and you just never noticed?
Old Nov 6, 2009 | 04:04 PM
Lord ET's Avatar
Is that a bike rack?
mine did this when my passenger door lock actuator failed. If a door doesn't lock the lights won't flash.
Old Nov 6, 2009 | 04:13 PM
Mazurfer's Avatar
Yeah, but I think it locks, and his hazards aren't working either. Could be related, might not be? Gives him one more thing to check though.
Good bet is the "flasher control module" after looking at the schematic, and that's located on the drivers side footwell. A lot of people do wiring over in that area, so that why I think it would be good to check those connectors and any aftermarket wiring in that area.
The Keyless control module is apparently located over on the passenger side and this could also be bad?????
Old Nov 7, 2009 | 07:39 AM
Ok...I will check what you guys said and then repost later today with the results.
Old Nov 9, 2009 | 08:46 AM
Ok....so i have checked all of the connections within the drivers side footwell and they all seem to be connected properly. There is no aftermarket wiring in the car so I dont think I have messed anything up on my own.
I wasn't sure which one is the flasher control module wire?
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXBae
Sep 14, 2015 03:54 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
