Check engine light is on.
Old Nov 2, 2009 | 11:03 AM
SayNoToPistons's Avatar
Wheels, not rims!!
Yesterday my check engine light came on. It was fine the whole day until after I turned the car off for the 2nd time during the day (didn't drive hard). Once i started the car, the light was on. The car drove fine without any apparent issues, pulls fine and sounds fine.
I did do the intake box mod. Took out both walls and one screen. I didn't reset the ECU because the car idled and drove fine. I did the mod a few days ago and logged over 100 miles with the mod.
Anyone want to guess the issue and solution?
Old Nov 2, 2009 | 11:12 AM
dozer's Avatar
on his 3rd rx8
year?mileage? was the CEL blinking? do you have aids?
Old Nov 2, 2009 | 11:24 AM
Wheels, not rims!!
04, 46k, stable CEL, possibly.
Old Nov 2, 2009 | 11:53 AM
dozer's Avatar
on his 3rd rx8
hmmmm ever changed out your gas cap?
Old Nov 2, 2009 | 12:03 PM
Wheels, not rims!!
Nope.
Old Nov 2, 2009 | 12:06 PM
dozer's Avatar
on his 3rd rx8
hmmm no loss of power, no blinking CEL, sounds like you gotta replace the gas cap...have the code read just to make sure
Old Nov 2, 2009 | 01:53 PM
josuar88's Avatar
The Crawlster
Could be the same problem I was having could be a a wide open intake valve. I drove my car hard until it fixed itself =]
Old Nov 2, 2009 | 02:05 PM
Vlaze's Avatar
The Angry Wheelchair
Take off the gas cap and then screw it in more than 5 clicks and see if that helps after a couple of days. Get the cel code at a gas station that services cars (just ask if they can do it when not busy free of charge).
Last but not least, break the light, problem solved.
Old Nov 4, 2009 | 04:53 PM
04RX8man's Avatar
Rotary Powered Countryboy
gas cap....autozone to get it read 4 free
Old Nov 4, 2009 | 11:59 PM
HockeyRX-8's Avatar
TNC
^+1
Old Nov 5, 2009 | 12:06 AM
hakuna matata!
If you wanna meet up somewhere tomorrow i can read the code for you.
But with the way the evap system self-check works and the driving cycle you did, I wouldn't be surprised it's a "gas cap" cel.
Old Nov 5, 2009 | 07:59 AM
kersh4w's Avatar
Hit & Run Magnet
i wouldnt have taken both screens out.
Old Nov 5, 2009 | 08:09 AM
Huey52's Avatar
Registered Zoom Zoomer
Agree. The Racing Beat intake is designed for one screen, but not the stock. Taking out the two plastic walls is no problem tho'.
But as cited, this CEL is probably just the gas cap. Half-dozen clicks just to be sure.
Old Nov 5, 2009 | 02:17 PM
Wheels, not rims!!
I left one screen in. I took both walls out though.
The CEL light went off the day before yesterday as if some sort of miracle happened.
Old Nov 5, 2009 | 02:19 PM
Wheels, not rims!!
Thanks for the offer. Just my luck, the Infinit's CEL came on the day before the RX8's CEL came on. It's still on for the Infiniti .
Old Nov 5, 2009 | 02:27 PM
Huey52's Avatar
Gas cap loose, Cat going bad, and/or O2 sensor(s) going bad are the likely culprits across most brands.
I've had one gas cap and several O2 sensors go bad since ECU's came on the scene, but never had a Cat go on me.
Of course the more you play with mod's .....
Damn computers.
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
