AudioLink/XCarLink USB MP3 player freaks the TPMS out
Old Nov 2, 2009 | 09:27 AM
shallowater's Avatar
After installing the AudioLink/XCarLink USB MP3 player, my TPMS begins to flash after 15 mins I drive the car.
At first I was not sure about the problem... my tire pressures are all good, then I though maybe it is just the weather (it is getting cold now), but then the TPMS just keep flashing everytime I drove for 15 mins or more. I took it the dealer and the dealer checked all sensor, cleared the code, and then finally concluded that the MP3 player maybe transmitting certain RF signal that freaks the MP3 player out. I am kind of convinced since it seems that things are all fine when I am not using the player or when I am using SD (instead of USB drive) with the MP3 player.
Did a quick search and found some similar complains. Guess it is NOT an isolated case, and the MP3 player is indeed driving the TPMS mad...lol. Wondering if there is any shield I can get to shield the RF signal from MP3 player to mess up with TPMS....
Old Nov 2, 2009 | 10:06 AM
czar's Avatar
Almost boosted
weird, guess because my old 6 didnt have that i never had a issue, could try foil heh pretty ghetto but it worked some what on keeping my roomates cellphone from beeping my speakers realy loud
Old Nov 2, 2009 | 10:17 AM
paulmasoner's Avatar
Asshole for hire
i know nothing of the product, and it may well have some interference issues
but it makes zero sense that USB use would have issues, and that SD card would not... most all SD readers present themselves as generic USB mass storage interface... which means it would look/behave/act exactly like a USB flash drive. In fact the only way they are different is in shape, and the method of communication between the SD card and its reader(but remember most all readers then behave/look/act like USB mass storage...)
Old Nov 2, 2009 | 10:27 AM
i guess it must be some sort of interference. as to the USB/SD difference, I am not quite sure. All I can say is that I just switched from USB drive to SD, and have not seen the TPMS problem in the past 3 days, during which I have done quite some city/highway driving... With USB drive, I get the TPMS going crazy like 9 out of 10 times.
Old Nov 5, 2009 | 09:29 PM
batangisip89's Avatar
im currently experiencing the same problem, but the only thing is that im only using the SD card and i get it after 15 min of driving, same as shallowwater... is there a shield that is out there?
Old Nov 6, 2009 | 08:20 AM
i remember reading somewhere on this forum that some folks are experiencing same problem and are gathering people with similar experience to build a stronger case when talking to the manufacturer. my problem is gone (at least for now) when using SD card, but if you are interested in a shield, you can do a search and find out if there is any update from those folks.
good luck.
Old Nov 7, 2009 | 02:17 PM
update... i tried using foil... yes veery ghetto but what ever works right?! ive had it in for the past couple days and no flashing TPMS....*knock on wood*
as of right now its just wrapped around the xcarlink but in the near future i may make a small foil lined box to clean up the look a bit.
Old Nov 10, 2009 | 12:49 PM
have you tried using SD card instead of USB drive. my problem has been gone after I switched to using SD card instead.
Old Nov 11, 2009 | 10:33 AM
that's just it I mentioned in my previous post that I only use SD card... but I still get the light. so far been a lil over a week or so with the foil an still no light...
Old Nov 12, 2009 | 11:50 PM
allanstrings's Avatar
I get the flashing whether i use the USB, SD, or direct mini jack to my laptop running Centrafuse. I guess i will line the box with foil...
Old Nov 13, 2009 | 01:28 AM
amazing_rx8's Avatar
Guy, anyone know if the same problem exists with XCarLink ipod integration kit or is it just with the USB/SD card kit? I was thinking of buying one, so your input will be greatly appreciated.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
vapor2
Jul 9, 2016 07:35 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
XianUnix
Sep 29, 2015 03:48 PM
04MazdaMan
Jul 15, 2015 08:23 PM
