DSC/ABS Malfunctioning after jump start
Old Nov 1, 2009 | 10:55 AM
Section 8's Avatar
So my wife killed the battery in the 8 by leaving the map light on, so I had to hook up the battery charger to get it started.
After firing up the car though, the dsc is completely off. I've tried resetting the ECU but no dice. Checked all the fuses and they are all good. Anyone see this problem before? it's an 05 touring with no mods, 42k on the odo.
Old Nov 1, 2009 | 11:05 AM
expo1's Avatar
He's as bad as Can
Did you reset the DSC??
zaitron's Avatar
You need to recalibrate the steering. If i remember correctly, you need to turn the steering wheel all the way to the left, and then all the way to the right. then turn off your car, and turn it back on. DSC and Traction Control lights should disappear..
check your owners manual for more details.
Old Nov 1, 2009 | 11:09 AM
Section 8's Avatar
Thanks for the quick replies guys. I didn't know there was a DSC reset procedure - I"m used to the no frills electronics of my RX7 LOL. I will do that today that must be what it is.
Old Nov 1, 2009 | 11:20 AM
Section 8's Avatar
That fixed it. That'll teach me not to look in the manual first. Thx again guys.
Old Nov 1, 2009 | 05:12 PM
Lebren's Avatar
RX8club group buy vendor
I'll be using this procedure later when pulling the battery to clean (and take pics for another thread) thanks Expo1!
talonhart2
Aug 26, 2015 04:14 PM
atmd
Aug 19, 2015 12:43 PM
T_Mags
Jul 24, 2015 11:29 AM
Kangarhew
Jul 18, 2015 08:27 PM
