CEL on again after replacing gas cap
I have an 04 rx8 with 59k on it and I had the CEL light come on a couple weeks ago. Went to auto zone and had the code pulled and it was the gas cap. So I replaced it with their aftermarket one and now the CEL came on again. Went to auto zone and had them pull it and it was the same problem. Air and dirt in the fuel system. Do i need a gas cap from mazda to fix the problem?
Spin the cap a half dozen clicks after refueling; believe it or not it makes a difference!
Autozone and similar used to reset the code for free, or a friend with an OBDII device.
If it still doesn't go away then you have a leak somewhere in your evap fuel system. The engine draws a vacuum on it when you start it, and if it doesn't hold it trips the CEL. It may not be the cap at all. It could be something like a vent hose or the gasket around the fuel level sending unit.
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
dbarber
Jul 25, 2015 01:34 PM
