Engine Light On
Old Oct 27, 2009 | 07:34 AM
Marcus2025's Avatar
Engine Light On
Hi guys. My engine light came on last week (and is now on AGAIN) so I took it to Mazda and the code they pulled said Intake Manifold valve stuck open. I haven't noticed any hesitation or anything and the car drives just as good as it did when I bought it. However, Mazda is trying to tell me that I need to replace the Intake Manifold Valve for $2200...I found this a little bit ago...
---Hesitation and/or a lack of power can be caused by the secondary shutter valve (SSV) in the intake manifold becoming stuck open due to carbon build up. This may occur with no Check Engine light illumination but eventually the light will illuminate. There is a cleaning procedure and a revised SSV to fix the problem.---
Mazda told me that they did they cleaning procedure, but didn't say anything about a revised Secondary Shutter Valve to fix the problem. My engine light came on again last night. Does anyone know anything about this issue?
Please, any advice would be greatly appreciated.
Old Oct 27, 2009 | 07:54 AM
Bigbacon's Avatar
2006 WB AT
search around the forum, there are certainly a few threads on this and how to fix it yourself, specially if it's stuck. Now after they cleaned it, do you know if it's the same code thats coming up or a new one?
Old Oct 27, 2009 | 08:10 AM
jsjjr's Avatar
His 8
There was another thread recently about this secondary valve....redline.. often. Carbon builds up around this valve because it doesn't open until around 6200 or 6500 rpm or so... That thread also gave instructions on how to unstick it..
Old Oct 28, 2009 | 07:03 AM
Marcus2025's Avatar
I found the threads on it. Thank you guys very much. I appreciate it!
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
