Allignment quick check
Old Oct 26, 2009 | 07:34 PM
invasion08's Avatar
No its your TPMS light which means one or more of your tires is low. Check your tire pressures in the morning.
Old Oct 26, 2009 | 07:38 PM
chino0314's Avatar
need to align your camera... lulz
Old Oct 26, 2009 | 07:40 PM
HockeyRX-8's Avatar
TNC
Originally Posted by invasion08
no its your tpms light which means one or more of your tires is low. Check your tire pressures in the morning.
+1.
Old Oct 26, 2009 | 08:26 PM
Juice's Avatar
I made some poos
1. This information can be found in your owners manual
2. If you do not have an owners manual, you can register on MazdaUSA website and download it for free
3. There is no alignment light at all, as you should know from reading your owners manual.
4. If you feel you need an alignment because the car isn't tracking straight, at least properly inflate your tires and drive the car again to see if your problems still occur.
Old Oct 26, 2009 | 08:28 PM
mkmike103's Avatar
Alignment light, thats a new one for me!
The light is for your TPMS, either it is not functioning properly (usually blinks), or one of your tires is low. Fill up your tires and it should go away.
Old Oct 26, 2009 | 08:50 PM
HWK11's Avatar
Lighting Yellow
yea just go to a gas station and fill your tires
Old Oct 27, 2009 | 07:05 PM
deadphoenix52's Avatar
meh.
or use the air compressor in the trunk.....
Old Oct 27, 2009 | 07:29 PM
HWK11's Avatar
Lighting Yellow
theres a air compressor in the trunk?
i never knew that . lol
Old Oct 28, 2009 | 07:16 PM
pup's Avatar
pup
holla if u hear me
no no no .....that light means your blinker fluid is low.....dang i cant believe im the only one who knows that.....u have to remove your glove box and blinker controls to get to the sump to refill it
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
czr
Sep 13, 2015 11:37 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
GARCIAC951
Sep 10, 2015 07:17 PM
