VOODOO8
10-25-2009, 03:04 PM
Here is one for both the AC thread searches and the Idle thread searches:
Air conditioner's magnetic clutch on my 03 build MT went bad on me, had to have the AC compressor replaced. Tech at my dealership (Mark at Werner Mazda in ManchVegas NH) had a bitch of a time getting the old compressor off - bolts seized - had to hit them with a torch (but I digress...).
New AC compressor is now installed and car is back home. Started it up today and noticed that I was suffering from the well known erratic idle syndrome. With fully warmed up engine the idle would periodically drop to almost nil, or the engine would stall, on a cycle that repeated about every 30 seconds +/- (I wasn't checking with a stop watch). Pop the hood to check it out. Discovered that every time the magnetic clutch engaged to cycle the new AC compressor, the engine would stumble. Once the clutch relaesed, the engine would surge to recovery, actually jumping to about 1200 RPMs, before settling back to around 800 RPMs.
Next time the AC compressor cycled on, same scenario. And so on, and so on...
The air conditioner was not actually turned on at the dashboard in the cabin, this was just the standard AC cycle the RX8 goes through even when it is not in use.
Anybody seen this before? Any fixes other than the new AC compressor may be a little "stiffer" than the old one at the moment and hence is putting too much drag on the motor when it engages to cycle?
