View Full Version : Dull spot of paint on hood fck
josuar88
10-24-2009, 09:54 PM
Ok so today I tried to use my mazda touch up paint on my car well I thought it looked like runny crap after it dried so I used some rubbing alcohol to get most of it off but now Im left with a noticeable dull spot I used some spray on wax to see if that would work nothing. So some suggestions please?
josuar88
10-24-2009, 10:18 PM
I mean I'm sure some easy polish goop from some auto parts store would do right?
05rex8
10-24-2009, 10:20 PM
yeah just polish it
maybe a light cutting compound depending how bad it is
josuar88
10-24-2009, 10:23 PM
Well like I said the touch up paint dried and I removed some of it but it left a dull spot ill look into the 3m polish i mean its not that the paint is missing its that the clear coat is gone i think
05rex8
10-24-2009, 11:01 PM
I doubt you took the clear coat off; rubbing alcohol cannot remove cured clear coat. It will dull it like what happened to you. In fact, paint thinner doesn't remove cured clear coat *very* easily. It is harder than you think.
