Tein Basic Coilover:
I have a bit of a fish tail type of feel when driving from the rear obviously.
Could not having a "rubber isolator"(springs sit on etc) cause this type of movement?
Could my swaybars and or end-links be the issue?
What about control arms/rods?
Has anyone else dealt with this issue before?
Thanks for any sort of advice
-Brandon
Talic
10-25-2009, 01:25 AM
check your tire pressure (low pressure creates the same feeling)
inspect everything is fastened properly (play in control arms or shock mounts)
check the 4 wheel alignment via laser (probibly not driving stright giving the fishtail feeling)
the swaybars and isolator are most likely not the problem
Lord ET
10-25-2009, 01:39 AM
pew pew pew
Tire pressure has not been checked for sometime now, so I will check it. I'll get it on a lift and check all suspension components. I got a 4 wheel alignment back in August but I guess I'll go or another one or at least check on the machine's computer to see if it's really that bad. I figured that you did not need the rubber isolator but wanted to make sure but was later told otherwise lol. I don't think its my sway bars either because when I installed them, they were then inspected by tons of people lol. Thanks for the advice.
