fan
01-12-2004, 07:19 PM
or maybe I should ask which one is the BEST?
also, do places such as pepboys and autozone sell the crush washer?
View Full Version : For DIY people, what oil filter do you use? fan 01-12-2004, 07:19 PM or maybe I should ask which one is the BEST? also, do places such as pepboys and autozone sell the crush washer? khoney 01-12-2004, 09:24 PM I go stock, on the advice of the best rotary mechanic in town. If not stock, I would go with an AMSOIL or Mobil-1 filter. Both are highly rated. rxeightr 01-12-2004, 09:46 PM Stock as well w2aew 01-15-2004, 10:47 PM Stock for me too (even though it is a little smaller than the one from the factory). Of course, I've only done one change so far, at 1500 miles. Planning on doing it again at 5K, and every 5K after that. On my other vehicles, I stick with Purolator or Motorcraft. One more question for the DIYers... I noticed that when I changed the oil that there was a bit of air bubbling/gurgling as I removed the filter (as the rubber gasket released from the sealing surface). I also noticed that I spilled about a tablespoon or so of oil from the filter. So, the question is: If I remove the filter very slowly to let the air enter the filter, will this help to drain the filter more effectively and give less spillage? If so, will poking a small hole in the top of the filter with an awl prior to removal result in the same draining effect? Just trying to minimize the amount of spilled oil to clean up. B-Nez 01-15-2004, 11:53 PM I've been using the Bosch 3300. My local Autozone only carries Fram (sucks), Motorcraft, Mobil1, Bosch, and a few AC Delco. B-Nez 01-15-2004, 11:58 PM Originally posted by w2aew I also noticed that I spilled about a tablespoon or so of oil from the filter. So, the question is: If I remove the filter very slowly to let the air enter the filter, will this help to drain the filter more effectively and give less spillage? If so, will poking a small hole in the top of the filter with an awl prior to removal result in the same draining effect? There had been some debate over hole-punching a while back. Here is one thread (http://www.rx8club.com/showthread.php?s=&postid=88025&highlight=oil+nail#post88025) that touched on it, but I know there was some more discussion in other threads. Here (http://www.rx8club.com/search.php?s=&action=showresults&searchid=280389&sortby=lastpost&sortorder=descending) are the results I got when I searched for the keywords 'oil' and 'nail'. |
