2009 rx8 radio removal
Old Oct 22, 2009 | 08:55 AM
joebennz's Avatar
the swirlinator
a quick question
are the 1st gen instructions for removing the radio also able to be followed to
remove a 2009 radio?
thanks
Old Oct 22, 2009 | 01:55 PM
epounds's Avatar
Yes. I used some of the instructions on this site and they helped me out. The steps are:
- Unscrew the shift ****.
- Pop off the shifter cover. It is all clips. Start where the parking brake is and work your way around.
- Remove two screws at the bottom of the ashtray. Pull it out and then remove the two connectors and the light. For the light, just stick a screwdriver in the top white tab and push it out.
- Remove the two black screws just under the A/C area.
- Remove the black panel under the steering wheel. the two clips are at the top and then it just falls out.
- Unscrew the silver metal plate that is just under the previous plastic piece.
- Now you can look at the side of the radio and see a silver bolt that holds it in. There is only one. Use a 10MM socket with a hinge on it to access this bolt.
- Pull the radio out. There are a few clips at the top, so you need to give it some effort.
- Remove the two connectors for the A/C.
- Remove the two radio connectors and connector for the antenna. The connectors are a bit of a pain, but I used a small screwdriver to press at the base of the clip to disengage it so the connector would just slide out.
That's it! Good luck.
-Erik
ei8ht
Aug 21, 2017 09:08 AM
michaelsk8er
Nov 9, 2015 07:06 AM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Aug 9, 2015 05:56 PM
MolecularConcept
Aug 5, 2015 04:43 PM
