Eradicator
01-12-2004, 04:38 PM
In the process of putting in some footwell lights, I accidentally crossed a couple wires that shouldn't have. One was from the circuit that gets power when the doors are opened or the locks are unlocked (commonly called the "dome light" signal). The other was from an ACC circuit, which I tapped from the back of the fuse panel in the driver-side footwell. I think it was fuse #3 (may have been #2).
Anyway, I had these two wires laying in the footwell while I was soldering some other stuff and getting ready to wire it all to a 3-way switch. When they touched, they got hot and I imagine they shorted something in the door switch (dome) circuit. Now, none of the lights come on when I open the door (activate the door switch), but the dome lights still work if I hit the buttons (the front map lights and the rear dome light).
I've been looking at the wiring diagram, provided to me by Rx-Appreci-8. On page 80, it details the interior lights circuit. I've checked the fuses in both the driver-footwell panel and under the hood. They all seem to be okay. I think this makes sense since I'm still able to use the map lights and the rear dome light. They work fine off the 15A "room" circuit, but they just won't activate via the door-switch signal. So, on the other end of the circuit, these go to the Keyless Control Module (pg 110-113). I've just started looking at the schematics for the KCM, but it looks like I'm not going to have an easy fix here. It might be that something internal to the KCM has fried and I will have to replace the entire unit.
Does anyone have any information that might help me here?
