RockfordFosgate
10-20-2009, 10:52 PM
Hi Folks,
after my workshop finally gave up I would like to post my troubles here hoping is there's somebody out there helping me getting my red one back on track.
First a little bit history:
In May 2009 i found a Nov. '05 with 76000 km on the clock for a reasonable price on the used car market in Shanghai. On test drive the only trouble it showed up was a broken wheel bearing, not a big issue since mazda is using standard bearings for 50 bucks. So I made it mine. Shortly after purchase the "Akropolis" issue came up (cooling water level low). Found a connector on the cooler broken due to material aging - very disappointing. Nevertheless the engine never run hot, I changed the radiator immediately.
One week later - warm start problems. Checked the PCM SW version - OK, so changed the spark plugs. No improvement, there for the engine came up with more and more rough idle and finally knocking @ 6000 - 7000 rpm.
At this point I should mention that my workshop is certified for the RX-8, but the guys there are not the smartest. Unfortunately in my small 5 mio people town there is only one RX-8 shop because there are only 3 rotaries running (!). So I found a copy of the workshop manual on the www and after 2 days fighting I convinced the workshop to go through the "knocking/pinging/detonation" troubleshooting procedure. Found low compression, kick or overhaul the engine :sadwavey:. Ignition, oil metering system, fuel pressure pump and fuel pressure regulator showed normal behavior. First I was thinking about overhauling the engine, but mazda blocked the spare parts for the RX-8's heart here in China. If you want to buy rotor seals, you have to apply for release, wait for Japan to confirm and then import the parts. Takes around 3 months. Forget it, order a brand new engine for 9000 US$ (yeah imported goods are luxury in China due to customs and tax).
I still need to find the root cause for the failure of the old engine by taking it apart, but first I should get the new one working... The "specialist" blames that on the bad fuel quality, I should fill 97 instead of 93. I guess he gets his cigarettes for free from SINOPEC. Honestly, I wouldn't fake the low grade fuel by taking high grade and stretching it, rather I would fake the expensive one...
When swapping the parts from the old engine to the new one, I found that the whole air intake system was so dirty, the built-in flaps were stuck and could not even be moved by hand and a lot of force. Have a look:
http://666kb.com/i/bdexdfj7jn3sjjs7e.jpg
Everything was cleaned, engine was assembled and implanted into my red colored tin box. This still happened last Saturday, unfortunately I got sick on Sunday and couldn't join the final assembly and the tune-up. According to the mazda guys everything went smooth and I went there to pick up the car on Monday morning. But there came the no-go, the engine was stalling at idle. So I left the car there and went to work. They were searching (according to check-list, but I don't really believe them) until Tuesday evening when they finally gave up and I took the car back.
Now I'm on my own with 9k drained from my bank account and a car that still behaves like a girl. Today morning I was driving it to work (50 km) and monitored the behavior:
- At cold start the engine is running on 2000 rpm for a while before lowering.
- After 30 sec it starts to swing between 750 and 1500 rpm, very rough at the lower end.
- The swinging window is getting smaller and smaller, suddenly the engine stalls.
- After 10 min in city traffic, the idle is stable @ 850 rpm.
- Driving at constant speed and rpm for a while and releasing the clutch then causes unstable idle again and sometimes stalling, even after 50 km.
- When pushing the throttle during unstable idle, the power comes with a delay, but with some kind of punch.
- The power output seems to be lower than before with the blown engine, but this could be a subjective impression because I don't rev it over 5000 right now and the engine sound is much more smooth than before.
According to mazda everything was checked, nothing abnormal was found. What I can confirm:
- No DTCs displayed
- fuel pressure OK
- injectors cleaned (2 times) and new seals
- ECT signal normal
- IAT signal normal
- ignition normal (no sparks, timing OK)
- APV operating normal
- purge valve operating normal
- secondary air injector pump operating normal
Please feel free to give me any hint what comes up in your minds, I will drink a barrel of finest Weihenstephaner Hefeweizen on the poster who can help me out of this disaster :worship:
Greetz
Mike from China
Edit: feel free to keep any spelling mistake you may find...
- No DTCs displayed
- fuel pressure OK
- ECT signal normal
- IAT signal normal
Greetz
Mike from China
