theused7151
10-16-2009, 03:34 PM
Do you need to remove the tailights to spray the tailights with VHT Night Shades? Or can you just cover up everything else and spray?
View Full Version : VHT Night Shades theused7151 10-16-2009, 03:34 PM Do you need to remove the tailights to spray the tailights with VHT Night Shades? Or can you just cover up everything else and spray? lokaldisruption 10-16-2009, 03:41 PM i dont recommend these...unless you have experience with spray paint...they are really runny and dont look that great imo after being done with it. but lay that clear coat after and its ok......i tried with parts on car/cover up rest = fail...i would take them off=) dhan 10-21-2009, 01:45 PM just take it off its really easy too.. im not great at spraypainting but my tailights and corners turned out great. just sand it a bit then around 4-5 thin layers of vht then around 3-4 clear coat. 10min in between to dry chino0314 10-21-2009, 02:17 PM if you dont take them off it WILL drip rxwarrior 10-22-2009, 01:03 AM +1 you definitely need to remove the lights first. I did the brake lights on my truck. I took them off and sprayed the whole can onto 3 lights, in light coats waiting 10 minutes in between. They turned out great and I didn't even sand or clearcoat. |
