josuar88
10-13-2009, 04:58 PM
That bad and what do I do with a full tank of it now? Wasn't paying attention when I was pumping gas until about a third of the way through fueling.
View Full Version : Accidentally put 87 in the REX josuar88 10-13-2009, 04:58 PM That bad and what do I do with a full tank of it now? Wasn't paying attention when I was pumping gas until about a third of the way through fueling. Red Devil 10-13-2009, 05:04 PM I'm at 90K on my original '04 engine, been using 87 octane pretty much since day one. Don't worry about it, just drive the car. Bullitt 10-13-2009, 05:05 PM Just "enjoy" a little less performance, and don't repeat. That's pretty much what my manual reads. Jasonawojo 10-13-2009, 05:06 PM Yeah, I also almost always use 87. So, unless you experience problems, nothing to worry about. josuar88 10-13-2009, 05:07 PM Well I haven't noticed any difference but I just wanted to make sure I was going to cause severe engine damage like the manual states even though manuals like to over exaggerate things sometimes. Bigbacon 10-13-2009, 05:12 PM Well I haven't noticed any difference but I just wanted to make sure I was going to cause severe engine damage like the manual states even though manuals like to over exaggerate things sometimes. you'll probably notice the difference when you go back to premium. I can certainly tell a difference in the performance between 89 and 93. josuar88 10-13-2009, 05:15 PM But not a problem my engine won't blow up or some crazy shit? Thats all I want to know klanham08 10-13-2009, 05:21 PM But not a problem my engine won't blow up or some crazy shit? Thats all I want to know You should be okay. I did that the first time I got my 8, and nothing happened. JTtheDude 10-13-2009, 05:24 PM I did it once in my 05 couple years back, it made the marbles in a can sound and I've never used anything but 93 since. Little powerloss but you should be ok. Bullitt 10-13-2009, 05:25 PM I seriously don't think so. My manual reads that you will likely experience a loss in performance at lower octane. If it could cause serious engine damage, I'd think it would be page 1 in red. You're gonna be okay. Red Devil 10-13-2009, 05:27 PM you'll probably notice the difference when you go back to premium. I can certainly tell a difference in the performance between 89 and 93. On the factory tune there is no knock detected, so it does not add fuel or pull timing in either leading or trailing plug based on either 87 or 93 octane. Old Rotor 10-13-2009, 05:36 PM But not a problem my engine won't blow up or some crazy shit? Thats all I want to know I can run 87 in the fall and winter when it's in the sixties. If your fuel is too low in octane the Rotary will let you know. Keep your Bose lower so you can listen for a new sound from your engine. If you do hear a new sound from your engine(when asking for more power) back off the throttle. Take it easy on this tank till its down at least half way before filling with prem. You don't want to push your car and hear the MIAC (Marbles In A Can) pre-ignition sound of a Rotary engine. It is very damaging! Nubo 10-13-2009, 05:42 PM Well I haven't noticed any difference but I just wanted to make sure I was going to cause severe engine damage like the manual states even though manuals like to over exaggerate things sometimes. I'm sorry, where in the manual does it state anything about severe engine damage with 87 octane gasoline? titaneum_grey 10-16-2009, 12:34 PM I agree woth OR, take it easy while using the lower octain as it can't stand up to the hotter temps. as well as the higher octaine. Or, you can just put a can of octaine booster in your tank ;-) rodjonathan 10-16-2009, 12:43 PM you should be fine just dont do it again |
