___________25mm (1inch) spacers 5x114.3 ______________
Old Oct 11, 2009 | 06:23 PM
kday's Avatar
These spacers are solid billet aluminum and are of high quality. The center bore size is 2.25" and there is no shimmering with these.
$160 for all 4 BRAND NEW
Located in Rosemead, CA
Old Oct 12, 2009 | 02:50 PM
kday's Avatar
ttt
Old Oct 14, 2009 | 03:26 PM
kday's Avatar
ttt
Old Oct 15, 2009 | 01:30 PM
kday's Avatar
bump this ttt
Old Oct 20, 2009 | 12:35 PM
kday's Avatar
Old Oct 20, 2009 | 12:53 PM
kersh4w's Avatar
Hit & Run Magnet
this is way too wide for stockers. or i would have been interested. good price.
Old Oct 20, 2009 | 11:32 PM
kday's Avatar
1 inch really isn't that wide
same spacers on stock rsx wheels
Old Oct 21, 2009 | 02:27 AM
luv4eternity's Avatar
Low is a lifestyle
any other pics of 1inch on an rx8 with stock wheels lowered ? if it looks good, im taking it off you ...which part CA are u in ? im in SJ
Old Oct 21, 2009 | 03:56 PM
kday's Avatar
I'm located in Los Angeles and no longer drive an rx8 so I can't take pictures but I've seen rx8's slammed on 19x8.5 and 19x9.5 what makes you think a 1 inch spacer isn't going to fit on a stock 18x8 wheel?
Old Oct 21, 2009 | 08:04 PM
TX
I bought 25MM for my stockers. there is also a member here with 25MM spacers on his gunmetal stockers and it looks sick. If these were hubcentric I would be all over it. I got what I thought was a sick deal on 25MM H&R hubcentric spacers and come to find out the bore size is too small
Old Oct 22, 2009 | 11:13 AM
jewagr007's Avatar
Rotary is a Lifestyle
Just because it works on 19x9.5's doesn't meen it will work on stocks. It all depends on the offset of the 19x9.5's. These would be ok on stocks if your car isn't lowered at all. If it is you will have to roll your fenders somewhat to prevent rub when taking bumps.
Old Oct 22, 2009 | 11:30 AM
25MM spacers on stocks wheels with a normal spring drop (teins, tanbe's, etc.) does not require fender modification.
Old Oct 22, 2009 | 02:27 PM
kday's Avatar
25mm is not as extravagant as you would think. The center bores are 2.25" and will clear most import setups as for being hub centric as long as you center them before torquing there really is no difference. I've run enough of them on many cars and know they're quality adapters.
Old Oct 23, 2009 | 02:14 PM
kday's Avatar
Old Oct 26, 2009 | 04:33 PM
kday's Avatar
Old Oct 28, 2009 | 03:31 PM
kday's Avatar
Old Oct 29, 2009 | 01:18 PM
kday's Avatar
ttt
Old Oct 30, 2009 | 02:11 PM
kday's Avatar
Old Nov 3, 2009 | 01:11 PM
kday's Avatar
Old Nov 6, 2009 | 01:16 PM
kday's Avatar
Old Nov 8, 2009 | 02:50 PM
kday's Avatar
ttt
Old Nov 11, 2009 | 03:56 PM
kday's Avatar
ttt
Old Nov 13, 2009 | 04:01 PM
kday's Avatar
ttt
Old Nov 15, 2009 | 12:53 PM
kday's Avatar
Old Nov 19, 2009 | 12:03 AM
kday's Avatar
