View Full Version : Stripped Spark Plug - Any suggestions???
tntmst
10-11-2009, 11:42 AM
Ok so the back rotor, trailing spark plug was a pain to get out :wallbash::wallbash::wallbash:, when I finally got it out, I saw why....
http://farm3.static.flickr.com/2482/4001484512_89af3efdc1.jpg
http://farm4.static.flickr.com/3513/4001486122_8760df4aae.jpg
So now I need some suggestions on how to fix spark plug hole so I can put in the new spark plug.
Read this thread, and I'm thinking of trying it out....
http://www.rx8club.com/showthread.php?t=164449&highlight=helicoil+spark+plug
Would like to know if anyone has some different suggestions??????
tntmst
10-11-2009, 11:44 AM
Looking for a way to fix by hand, without power tools if at all possible.
bumblebeerx8
10-11-2009, 11:45 AM
the only thing i can suggest it chasing it with a tap i had to do mine on my explorer because the one is a pain and alot of people leave it in. once they do take it out this happens, or anti seize was never used
bumblebeerx8
yep use a tap and crank it in with a cresent wrench
alnielsen
Heli-Coil - http://www.emhart.com/products/helicoil.asp
You may want a mechanic experienced in installing one to do it.
bumblebeerx8
10-11-2009, 11:47 AM
fastenal or some hardware stores will have them im sure if you take one of the plugs with you good threads of corse you can match it up with a nut to find out what thread and corseness you will need
bumblebeerx8
10-11-2009, 11:49 AM
that may work too but wont the hole have to be drilled oversized to accomidate the width of the stainless coil
alnielsen
10-11-2009, 11:53 AM
Yes, but if you look at the threads of the plug, a lot of the holes thread material is gone. I fear tapping out the hole won't be successful.
I've never used the product. There may be a better way. I just know helicoils have been used for stripped plug holes.
bumblebeerx8
10-11-2009, 12:02 PM
its questionable not knowing how much is there if its less that half tapping would be questionable if not impossible. and if you have to sleeve deffenty take it somewhere to have done by someone that has done it and takes care of a mess up that could save you in the long run
tntmst
10-11-2009, 12:10 PM
The new spark plug will not even go in far enough to stay in.
of course everyone around here is closed on sundays so i will have some calling to do first thing in the morning.
I,m headed up to ACE to check out the kit that they have and see if it will be worth a try.
bumblebeerx8
10-11-2009, 12:58 PM
good luck^ i pulled my plugs out yesterday and prayed this would not happen not knowing who did it before me
