car stalls when thrown into neutral when coasting.
Old Oct 9, 2009 | 11:35 PM
iLikeEatPoo's Avatar
The Great Dick
I just replaced my alt that went out and now when test driving my car would stall out. I thought it was a vac leak at first but when spraying starting fluid into my bay I could not detect a leak.
Also I have a VLAD removed and plugged off. the senor is no longer hooked up as well.. would this cause a problem such as mine? Thanks.
Old Oct 9, 2009 | 11:52 PM
pineapplesoymilk's Avatar
pure sex
never heard or that happening what does your car usually idle at and when you replaced the alt was your idle lower as normal?
Old Oct 9, 2009 | 11:59 PM
Jon316G's Avatar
Grasshopper
I've had times after a PCM reset where the car would come REAL close to stalling.
It didn't help that I had old spark plugs at that time too.
So its possible that your car is still learning the fuel trims and old plugs are preventing the car from recovering/learning its idle position.
I say give it a couple more drive cycles and see if it improves.
If not, then come back and we'll go from there.
Also, verify that the battery connections are tight and the belt isn't loose.
And its VFAD, not VLAD
Variable Fresh Air Duct
Old Oct 10, 2009 | 01:08 AM
Car stalling after battery unplugged is not normal.
that simply means something is "on its way out"
Im not trying to scared you guys, but its a sad truth.
I would say check the TB first. it goes bad faster than most think it is (and its barely noticeable in daily driving)
Old Oct 10, 2009 | 04:38 AM
Jon316G's Avatar
Grasshopper
I think you're jumping to the "worst case" senario nycgps.
Too many other factors can result in this occurring, so I wouldn't say its a "dying" engine right away.
Like I mentioned above, I had the same thing occur when I had bad spark plugs (actually they were the RX7 plugs).
Changed them out, now it doesn't do that whenever the battery is disconnected.
This same symptom also occurred when a local 8 had his SSV stuck closed.
And this was only noticeable right after the battery was disconnected.
He would push in the clutch pedal and the RPMs would drop all the way to zero.
It appeared like the car never attempted to stabilize its idle... just died.
After I freed the stuck valve and "zoom-zoom" cleaned the engine, the "dying RPM drop" didn't return.
I see too many ridiculous posts from people saying, "sorry bud, sounds like a bad engine" without properly troubleshooting/diagnosing the issue.
Not saying it can't be a bad engine, but we need to quit suggesting it right away (unless its really obvious).
OK... I'll get off the soap box now
Old Oct 10, 2009 | 08:36 AM
The Great Dick
It idles fine when just sitting there. it's only when coasting in neutral that it stalls. and if I'm going slower, like say 20-30ish it tries to recover it.
I can also save it from stalling out by applying gas. I'll go ahead and pull the plugs to see if they are dirty. But I'm pretty sure they are fine since just bought the car about 5k miles ago and it had brand new plugs and wires in it.
Oh I forgot to mention I'm running a FD Alternator.
Old Oct 10, 2009 | 03:10 PM
The Great Dick
It doesn't seem to want to stall anymore but when rolling down a hill I applied the brakes and idle dropped pretty low. Also I had this problem before when I took out VFAD and put it back on and it fixed it. Now I took it off again and it's happening again. Did I miss something?
Old Oct 10, 2009 | 06:26 PM
Jon316G's Avatar
Grasshopper
Are you capping the nipple behind the throttle body?
Old Oct 10, 2009 | 07:06 PM
The Great Dick
Yes I have. It seems to only stall when going above 50 coasting.
Old May 5, 2015 | 04:55 PM
HotIcedTea's Avatar
Anyone ever figure this problem out? I have the exact same thing happening
Old May 29, 2015 | 02:38 AM
srx600guy's Avatar
I've heard of this happening when the neutral switches go out. do a test on your neutral switch and see if it needs to be replaced
Old May 29, 2015 | 11:49 AM
wcs's Avatar
wcs
no agenda
Ya you bumped a 6 year old thread.
I don't think you're going to get an answer
Old May 29, 2015 | 04:53 PM
Harlan's Avatar
I think he already did. The neutral switch seems a very likely suspect. Especially if the problem doesn't appear when the clutch is pressed in.
Old May 29, 2015 | 05:16 PM
HotIcedTea's Avatar
Nah I haven't figured it out yet. I replaced my neutral switch and it still happens. I think it may be maf related. I cleaned mine but it didn't fix anything. Ordered a new one And it's on the way. We shall see on Monday if that fixes it
Old May 29, 2015 | 05:32 PM
wcs's Avatar
wcs
no agenda
I meant from the OP
Old May 31, 2015 | 02:43 AM
srx600guy's Avatar
dang, i am shamed to be incorrect
Dokuji
Nov 1, 2016 02:51 PM
RayBarron
Oct 19, 2015 08:08 PM
Quato_jr
Aug 4, 2015 09:22 AM
vetteor8
Jul 25, 2015 11:43 AM
Belalnabi
Jul 17, 2015 07:48 PM
