Fuel System Pressure
Old Oct 9, 2009 | 09:09 PM
RX844's Avatar
RX844
Hi Folks,
Quick one, can anyone help me with the following question. My 2003 RX-8 has just had its 300,000 km service done and the mechanic thinks the Fuel pressure regulator might be faulty as I seem to be using a bit more fuel and need to refill sooner than normal. Does anyone know where the Fuel pressure regulator is located and what is the normal running pressure?? Cheers - Wayne.
Old Oct 9, 2009 | 09:24 PM
It's in the pump assembly and not adjustable...
If you have made it 300K KM then you need a new pump.....you got lucky it lasted that long
Old Oct 9, 2009 | 09:47 PM
rodjonathan's Avatar
silent assasin
yessir change thr pump it majes a huje diferencr
Old Oct 10, 2009 | 02:28 AM
takahashi's Avatar
5x more km than me !!!!
New pump should do well.
Old Oct 11, 2009 | 03:46 PM
rotarenvy's Avatar
have a look at your long term trims.
the only way to use more fuel is to have high fuel pressure and have a rich mixture.
the engine management will compensate for this to a point and your trims should show the pcm trimming fuel.
Old Oct 11, 2009 | 03:55 PM
Easy_E1's Avatar
Originally Posted by RX844
Hi Folks,
Not going to happen.
Your going to use the amount of fuel needed by the engine load and what the ECU dictates. If fuel pressure was lower than recommended then you could loose power because of a lack of fuel pressure. If your fuel pressure is low I would recommend a new pump. As far as bad gas mileage related to the fuel pump. Nope. Lack of power, yep.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
tgaffner
Sep 7, 2015 08:49 PM
