aftermarket custom inltet manifold
Old Oct 8, 2009 | 05:34 PM
florent75's Avatar
Hi
I see 2 years ago a compagny doing custom aluminium intlet manifold
but now, impossible to remember the name of the compagny and a link to buy it
if someone can help me
thanks
Old Oct 11, 2009 | 01:43 PM
florent75's Avatar
up
nobody remember the compagny ????
Old Jul 14, 2010 | 06:34 AM
Dark_Knight's Avatar
Hi there I am from Singapore. Not sure if you interested with the Aluminium intake manifold fabricated by my company.
Please click on the following link for more pictures and info:
http://www.rx8clubsingapore.com/viewtopic.php?t=4975
Old Jul 14, 2010 | 10:09 AM
8upbad's Avatar
Jared
That manifold looks awesome Darky. What type of sound difference did it make? And does it make any power for n/a guys?
Old Jul 14, 2010 | 02:41 PM
lilring's Avatar
Finally a MT
very intresting.. i wonder how much it is
Old Jul 15, 2010 | 01:09 AM
As I am supplying this to a vendor in USA, I will not be able to disclose the pricing openly unless things do not work out, than I will start selling this through my own company.
As for who I be supplying to, I will let the vendor to decide if he want to let you guys know in-advance or later ;-)
Old Jul 15, 2010 | 01:41 AM
laythor's Avatar
I zoom therefore I am.
reserved for future lawls
and future counter-counter-lawls
Old Jul 15, 2010 | 05:04 PM
Reserved for future counter-lawls
Old Jul 15, 2010 | 05:10 PM
^ What are your thoughts on this IM guys? Is it even needed?
Old Jul 15, 2010 | 06:57 PM
bse50's Avatar
#50
It's a cool looking probably not needed upgrade (or downgrade). The stock intake works pretty well and making it any larger without at least mating the other side to the new diameters could lead to counter-productive results.
With the pics provided you only see that it, in facts, looks pretty cool. Seeing how it connects to the stock lower manifold is all that matters but still i'm not sure that changing its volume\diameter may help at high rpms, while it will probably vary the midrange power-curve somehow.
Good or bad only a dyno or some maf datalog can tell, for sure in a NA car operating at the stock rpm range it won't do much.
Old Jul 15, 2010 | 07:21 PM
Charles R. Hill's Avatar
Owner of BHR
This is a 4-port/AT manifold.
Old Jul 15, 2010 | 07:37 PM
bse50's Avatar
#50
Uhm... I must be losing my bits then! From reading his post on rx8clubsingapore.com I thought he made both versions.
Old Jul 15, 2010 | 11:37 PM
Yup, I made two versions, one for 4AT and 5MT, the other for 6AT and 6MT.
This aluminium intake manifold follows the design of the 6MT/AT stock manifold but with small modifications. This intake can be modify to fit on 4AT/5MT which I had done and installed in my car, and is working very well, no issue at all.
For my car setup, it is a 4AT, Greddy TC, Mild Port engine.
I dyno my car with two different setup, same tuner and dyno machine:
1st one is with Microtech ECU, BHR Ignition System, 6 Injectors (Two injectors on Manifold which was done up by a local workshop). I got 250hp.
2nd one is with Autronic ECU, Autronic CDI Ignition System, 4 Injectors (Non on Manifold), change the manifold to the one manufactured by my company. I got 253hp.
However for this, it is very hard for me to determine which cause the increase in horse power.
Thus I am waiting for four of my sample to send back to me before I can arrange a stock RX8 for Dyno session and test if it makes any difference between the stock manifold and the aluminium manifold.
Old Jul 16, 2010 | 09:18 AM
Cool. And you could PC it any color you want.
Old Jul 16, 2010 | 09:32 AM
Just to confirm, PC means prime coat? If I got this right than the answer is yes, any color you want
Old Sep 11, 2010 | 04:13 PM
florent75's Avatar
sorry, did not see your post before mister dark knight
I like to send you a pm, but impossible
can you please give me the price and shipping price to france
and delay
thanks
Old Sep 12, 2010 | 08:20 AM
Hi there, will you like to try to PM me again? I just enable that function.
Old Sep 12, 2010 | 11:10 AM
Nemesis8's Avatar
Bigus Rotus
I think some of us know who this vendor here in the US is, and I cannot stress this enough, that if it is in fact who I think it is, you have hooked up with the correct one.
Old Sep 17, 2010 | 06:03 PM
Rote8's Avatar
I wonder if Easy could "break" these....
/Sorry
Old Sep 18, 2010 | 09:59 AM
Rotr8's Avatar
whines all the way home
Im suprised that no one has brought up the possible heat soak issues yet.
Old Sep 19, 2010 | 10:51 AM
Frosty288's Avatar
n0 pants
Even if the manifold were to get hot enough, it wouldn't be much difference from the stock one. Air is moving through at a fast enough rate that the IAT wouldn't rise high enough to be of concern. It's like having 200* coolant running through our throttle bodies, or having a LIM that sits right above the exhaust
Correct me if I am wrong
Old Sep 19, 2010 | 10:58 AM
bse50's Avatar
#50
You're right if you don't take traffic or the likes into consideration
Even with my AEM intake if i drive through stop and go traffic my IAT goes up by a modest amount.
Old Sep 19, 2010 | 12:44 PM
Nemesis8's Avatar
Bigus Rotus
I think he meant "Powder Coat" maybe?
Old Sep 23, 2010 | 01:04 PM
09Factor's Avatar
Original Turbo 'd Auto !!
This looks like my next preformance mod. I need to speak with your USofA vendor.
Old Sep 23, 2010 | 01:21 PM
FastFreddy61's Avatar
Too bad you cant cut out the middle man, who will for sure make $100.00 or more on each unit, like the midpipes made in china and sold on thru "vendors". This unit will benifeit those Nitrous users who forget to purge the system.
