2nd gear grinds! How much to repair??
how many miles on your 8?
Are you using OEM fluids?
How long has it been grinding for?
It could be an issue with the synchros OR.... it could actually be your clutch pedal. If the pedal welds are flexing then the clutch isn't engaging properly and you'll grind. Look at NYCGPS's thread on his clutch pedal snapping and you'll see which welds can be affected.
Also, the pedal is adjustable, you might check to see if that helps.
nowakm99
Oct 9, 2015 07:10 AM
nferguson88
Oct 6, 2015 12:45 PM
