Loss Of Power and Rattle from Transmission
Old Oct 6, 2009 | 02:04 PM
Evan0925's Avatar
I Can Has Rx8?
Error
Error
Old Oct 6, 2009 | 05:21 PM
corners's Avatar
An RX ate my baby
Ask them to check the compression, and check the ECU for misfire codes. Chances are its your coil packs and/or plugs, though. Sounds like a misfire. Hopefully not anything worse than that.
Old Oct 6, 2009 | 08:50 PM
Evan0925's Avatar
I Can Has Rx8?
I did get misfire codes. 1 on Rotor 1 and 2 on 2.
This mean coils?
Old Oct 6, 2009 | 08:51 PM
xun4gvn4everx's Avatar
True love is blue x2
whens the last time you replace your coils, plugs, and wires?
Old Oct 6, 2009 | 09:03 PM
Evan0925's Avatar
I Can Has Rx8?
Plugs about 6K ago.
Wires and Coils never. I haven't had a single issue with them. I thought this might be the cause but I can't explain the horrible sound from the transmission hump.
Old Oct 6, 2009 | 09:08 PM
It's a domino effect. bad coils, leads to bad plugs, which leads to bad cat. Replace your coils and wires IMMEDIATLY!!! They are only good for 35k. And if you have the money, upgrade to BHR or other well known aftermarket brand and you will find the extra few bucks are very worth it. Your cat may be bad, from your symptoms. The dealership can tend to be lazy and not "actually" check your cat. Your best bet is to replace the wires and coils, check your plugs (cause if your coils were bad, they could have ruined your new plugs), and check your cat. Checking the cat is easy, just three bolts and look inside
mlampard
Nov 21, 2023 08:11 PM
Js3810
Jan 7, 2017 04:21 PM
anphelps30
Feb 13, 2013 05:29 PM
04RX-8GT6sp
Sep 7, 2012 04:55 PM
240sxdm
May 13, 2007 07:14 PM
