what is replaced when they put a "new engine" in the rx8?
Old Oct 6, 2009 | 09:31 AM
andyc10's Avatar
andyeprx8
TX what is replaced when they put a "new engine" in the rx8?
they dont really drop a new renisis in the car.what parts are replaced when the engine gives out? anybody know?
Old Oct 6, 2009 | 09:35 AM
dozer's Avatar
on his 3rd rx8
they give you a re manufactured engine, take out the old block and put the reman block in
Old Oct 6, 2009 | 09:39 AM
expo1's Avatar
He's as bad as Can
You get an engine, an OEM flywheel, water pump, some gaskets, oil & antifreeze. Unless you ask ( and pay) they will even reuse your spark plugs.
Your 2nd engine having problems??
Old Oct 6, 2009 | 09:50 AM
expo1's Avatar
He's as bad as Can
When mine was installed I did some extras that are easy to do with the engine removed.
I still had the original 'slow' starter, I had the newer one installed.
New belts and radiator hoses.
Mazmart Water pump instead of OEM
Depending on mileage get a new clutch & lighter flywheel
Supplied the plugs, oil filter, oil, antifreeze and distilled water
New engine mounts
Old Oct 6, 2009 | 11:30 AM
andyc10's Avatar
andyeprx8
actually i got the car on its second engine and then shortly had to replace it.
its been about a year since they put the new one in. im worried i might need a new one soon cuz i saw some smoke comming out my exaust the other day when i started it.
Old Oct 6, 2009 | 12:43 PM
You might get some smoke at start up, its pretty normal, cuz natually your engine will have water overnight (air has water in them, remember that)
but if its constantly getting smoke. you might have a coolant seal problem.
Panthersn
Jul 13, 2021 06:30 AM
ShadowGryphon
Jul 29, 2015 05:40 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
Belalnabi
Jul 17, 2015 07:48 PM
