help painting emblems
Old Oct 6, 2009 | 06:45 AM
Rotary_Guy's Avatar
Loud enough for ya???
help! painted emblem on front first as a test, glad i did. i used a metallic gunmetal which looks beautiful usually, but when this dried it turned a disgusting matte grey color... almost primer-like. why? and what can i do to fix it?
Old Oct 6, 2009 | 08:25 AM
gh8st's Avatar
STiMPACK
did you.. sand, primer x2, paint x2, clear coat x2?
Old Oct 6, 2009 | 08:37 AM
StormyWankel's Avatar
EVOLVChicago.org
Was the paint made for plastic? It sounds like it ate away at the plastic...always sand, always primer, always clear...quick search would have brought you to that information
Old Oct 6, 2009 | 09:14 AM
chino0314's Avatar
what grit sand paper did you use ghost?
Old Oct 6, 2009 | 09:30 AM
gh8st's Avatar
STiMPACK
400 grit i wanted the flat black look. i coated with the matte clear coat
Old Oct 6, 2009 | 02:28 PM
lilring's Avatar
Finally a MT
Try using bleach to clean the emblems then sand it and rise it.. then go with the primer and paint.. thats what I did and it came out the flat black. ohh and for the paint I used Krylon Fusion paint which worked great!
Old Oct 6, 2009 | 04:34 PM
Rotary_Guy's Avatar
cool, thank you for the tips guys.
Old Nov 10, 2009 | 12:32 AM
WTBRotary!'s Avatar
Drummond Built
Reposted on this post sense its more recent...
you see me and my friends tried a experiment with DIY painting a crappy dealer emblem. We sanded it up a little with like 220 grit, then we primed it twice, shot it with rustoleum black paint for plastic (which btw the black wasnt black enough for me and it seemed somewhat gray) and after 2 shots of that we then put 2 coats of clear on it and the last coat of clear somewhat bubbled... Wasnt very satisfying 2 hours to see the project go to ****.
Did you put primer on before? If so how many coats?
Did you put a clearcoat on? and if so how many coats of that?
What grit sandpaper should be used?
Any help would be appreciated...
Old Nov 10, 2009 | 09:40 AM
lilring's Avatar
Finally a MT
Did you put primer on before? If so how many coats? I used 4 coats of primer but i did it very light
Did you put a clearcoat on? and if so how many coats of that? I did not use clear coat
What grit sandpaper should be used? Sorry I dont remember it was to long ago.
Use the Kyrlon Fusion Black paint, you will get better results
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
djp6783
Sep 19, 2015 12:12 PM
