9krpmrx8
10-05-2009, 11:27 AM
I know its posted somewhere but I searched and could not find sleepy-z's post. I know it varies somewhat but does anyone know if the bearings are replaced every time?
View Full Version : What is included in a factory rebuild? 9krpmrx8 10-05-2009, 11:27 AM I know its posted somewhere but I searched and could not find sleepy-z's post. I know it varies somewhat but does anyone know if the bearings are replaced every time? nycgps 10-05-2009, 12:27 PM I found it on my first try, came up on my search as the first topic you n00b ! SEARCH !!!! :lol: Rebuilt engine parts to be exact.....maybe 20% chance I built it btw.... New parts guaranteed... Rotors and components on the rotor like springs/seals, water pump, oil pan, all rubber/metal seals/gaskets, bearings for stat. gears and rotors . 50/50 shot of new parts..... Some housing are new, pulley, flywheel can be used btw but 75% are new roughly, eccentric shaft is usually used but chance of a new one. Used........ Some housings, pulleys, flywheels, stationary gears are used but with bearings pressed in by yours truely(apperantly I am the only one there that is capable of doing it without messing up), parts in the oil pan(sensor, baffle plate so on), oil pump/chain. BTW small note, all oil pans are updated to the newer style(metal baffle plate added). 9krpmrx8 10-05-2009, 12:38 PM Damn it, i knew he posted that info. I searched for like ten minutes through his posts and didn't find shit. Thanks. So all the bearings are new. But soem stuff is missing like teh water pump and stuff right? nycgps 10-05-2009, 12:57 PM Damn it, i knew he posted that info. I searched for like ten minutes through his posts and didn't find shit. Thanks. So all the bearings are new. But soem stuff is missing like teh water pump and stuff right? Water pump and Thermostats are always brand new. cuz its not worth it for a 100 dollar part fuxk a 3000 dollar engine up. in the other words, a Reman will have roughly 80%+ brand new parts. |
