car accident, need answers
Old Oct 4, 2009 | 08:57 PM
leerx8bk's Avatar
Got hit on the drivers side. Now when i turn the steering wheel only one the right side wheel turns. The drivers side wheel doesnt move at all.
What is wrong and how much to fix it???
Old Oct 4, 2009 | 08:58 PM
Uh. take it to the shop dude. No one can answer without seeing all the damage.
Old Oct 4, 2009 | 09:05 PM
leerx8bk's Avatar
The rim has scrathces on it thats the only thing i see
i just want to know what it could be??
Old Oct 4, 2009 | 09:06 PM
Steering tie rod end almost for sure. But if it broke several other things could have been tweaked.
Old Oct 4, 2009 | 09:10 PM
leerx8bk's Avatar
How much could that cost, give me a rough estimate
Old Oct 4, 2009 | 09:12 PM
Chispas.
Old Oct 4, 2009 | 09:16 PM
The steering rod ends are about $60.00 so if you just broke that without damaging anything else then your okay. But if your screwed up the rack itself, it's like $1,000.00 because its electric. This is for parts.
Old Oct 4, 2009 | 09:17 PM
leerx8bk's Avatar
Wow thanx, its that a pic of an rx8 rack??
Old Oct 4, 2009 | 09:18 PM
Yes that is the whole front suspension setup.
Old Oct 5, 2009 | 01:51 AM
At least 1K
Old Oct 6, 2009 | 05:19 PM
corners's Avatar
An RX ate my baby
If you broke a tie rod I think it would be safest to replace all the ball joints, the control arms, and wheel bearings on that side. That big of an impact certainly broke something else as well. Chances are the wheel is also bent. I think $1k is the minimum. That's a serious hit. You will need a full alignment after all the work.
Old Oct 7, 2009 | 07:28 AM
leerx8bk's Avatar
broke tie rods and something else got split in half. it ended up costing 527 to fix. and a rack from mazda is 1400 dollars
Skyl3r
Dec 2, 2019 04:51 PM
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Obivious
Jul 29, 2015 05:57 PM
ken-x8
Jul 20, 2015 02:40 PM
reverse01134
Jul 16, 2015 10:27 PM
