cel flash codes?
Old Oct 3, 2009 | 05:56 PM
bgreene's Avatar
Time of your life, kid...
Question cel flash codes?
I've done a half dozen searches both here and on google, so if this is already up somewhere apologies but I haven't been able to find it.
I'm getting a blinking code from my CEL with the key on but engine not running and I can't find anything in the shop manual to interpret it (owners manual has vanished somewhere in my place).
The blink pattern is 7 slow then 1 fast after about 10-15 seconds solid. No lights come on while running, and the car mostly runs fine. I just replaced the battery a couple days ago, and have been in "relearn" mode so there have been some stalls at idle/stopping but those have mostly cleared up. I have done the dsc/steering reset (although not immediately after putting in the batt), and have done the 20-brake sensor reset.
I'm running a 2004 6MT with 69k miles that I bought new in 12/2003 and have the most current flash and all TSBs adressed.
Trying to avoid paying another $100 to find out it's just some false or unimportant code after nearly getting taken for a total of $350 for a neutral switch fail code which was caused by driving in LAX traffic for a week without knowing what makes that code come up.
thanks in advance to anyone who can help with this.
Old Oct 3, 2009 | 05:59 PM
Never fear, Jedi is here!
if you turn the key but do not start the car, the CEL will begin blinking. It spooked me the first time I saw it but it's perfectly normal.
Old Oct 3, 2009 | 06:02 PM
expo1's Avatar
He's as bad as Can
Need a code reader, some auto parts stores will read it for free. You also might try to find another 8 owner with a reader. You cannot tell anything based on the flashes.
EDIT: I am going to assume since you had the car a long time you were not referring to the normal startup sequence Jedi54 mentioned.
Old Oct 5, 2009 | 12:09 PM
bgreene's Avatar
Thumbs up
thanks for the responses. the relearn is finally complete and the car's idling as well as (maybe a little better than) ever.
whatever the cel blink was, I haven't been able to get it to happen again since the relearn completed (and I re-did the steering sensor reset just to be safe).
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
