CEL light- does resetting affect traction control?
Old Oct 3, 2009 | 01:31 PM
Darzan's Avatar
I have a 04 rx8 with 58k on it and just had the coils and plugs replaced about a month ago at a mazda dealership and now the CEL has come on. I know this is a common issue. I was going to try and reset it by unhooking the battery for a few mins but I was wondering if this affects the traction control and if I would have to reset that?
Old Oct 3, 2009 | 01:42 PM
you should get the code pulled ot make sure it's not a new issue.
if you unplug the battery, it shouldn't affect the TC.
Old Oct 3, 2009 | 02:25 PM
Darzan's Avatar
does autozone pull codes for free?
Old Oct 3, 2009 | 02:26 PM
they usually do.
Old Oct 3, 2009 | 02:28 PM
xun4gvn4everx's Avatar
True love is blue x2
+1 on getting the code pulled first.
If you unplug the battery, the TC will flash at you until it relearns itself. You can do this by simply turning the wheel to the left and right after starting it back up.
Old Oct 3, 2009 | 03:38 PM
mulkio's Avatar
Under-prepared
You could have your read your Owners Manual. Much wisdom it contains.
Old Oct 4, 2009 | 12:30 AM
Darzan's Avatar
pulled the code at autozone and it looks like it's just a bad gas cap. So hopefully that will fix it
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
pjwermuth
Sep 28, 2015 11:36 PM
