Abs and Traction control
Old Oct 3, 2009 | 12:17 PM
shinka911's Avatar
Help!!! Abs and Traction control dont wont work
I have a turboed 8, only thing else is spark plug wires, and i recently put the mazsport cooling mod on it. now every time i drive after start up, a few miles down the road my abs and traction control lights come on ( like if you hold the buttom for 7 seconds) and traction control and abs are indeed shut off. Im wondering why it keeps doing this, i feel it has something to do wiht the mazsport mod, becuase it started right after i installed that.
Old Oct 3, 2009 | 08:34 PM
shinka911's Avatar
Bump
Old Oct 4, 2009 | 03:02 PM
shinka911's Avatar
No one has any idea what this is
Old Oct 6, 2009 | 11:58 AM
tasteslikechicken's Avatar
Read this thread:
https://www.rx8club.com/series-i-trouble-shooting-95/power-steering-failure-107481/
I have the same problem. Losing DSC/ABS is nothing too big, the loss of power steering at speed is a rather disturbing thought.
Old Oct 6, 2009 | 12:35 PM
bose's Avatar
Reginald P. Billingsly
Check your fuse's, look for the stop fuse in particular it's a blue 15a fuse in the under hood fuse box. I had the same thing happen and that fuse was blown. I had a dead short in the wiring harness for the third brake light. It would only blow when the trunk was closed.
Here's a link to the thread that helped me: https://www.rx8club.com/showthread.p...highlight=stop
Old Oct 6, 2009 | 02:28 PM
kersh4w's Avatar
Hit & Run Magnet
which mazsport mod?
Old Oct 7, 2009 | 08:21 AM
shinka911's Avatar
It is the mazsport mod that turns your stock cooling fans on. ill check the fuse today and see it its blown or not. thanks guys.
Old Oct 12, 2009 | 09:43 PM
shinka911's Avatar
I checked all the fuses for dsc, the room, and the stop they were all fine. im going to try the reset but taking off the positive terminal for 40 seconds and see f that works. possibly the volts dropped to low
Old Oct 12, 2009 | 09:47 PM
shinka911's Avatar
also my cruise control has stopped working if that helps o the diagnosis
Old Oct 14, 2009 | 12:36 PM
Chris's Avatar
Turbo Member
this might be a stupid question bc I dont think you would have made this mistake (i hope) but are you certain you put the mazsport control modules in the right slots? check and make sure you replaced the fans and not the dsc modules
Old Oct 14, 2009 | 07:26 PM
shinka911's Avatar
hahaha no they are in the right spot, the problem didnt happen till about 200 miles after i put it on, im thinking it might be a voltage problem. But i might take it in to mazda to see what they say.
Old Oct 14, 2009 | 07:41 PM
nate340's Avatar
check the wheel speed sensors. this may be unrelated to the fan mod. does your trac and abs work for the first few miles before the light turns off?
Old Oct 14, 2009 | 08:05 PM
shinka911's Avatar
yeah everything works fine for like a couple of miles or so, then it shuts off. how would i go about checking the wheel senors?
Old Oct 15, 2009 | 10:05 AM
iLikeEatPoo's Avatar
The Great Dick
Same thing happened to be except I lost power steering as well. Turned out my alt died and I had to drive 20 minutes home on just battery life.
Did you try the reset for traction control of turning the wheel full lock left then full lock right?
Old Oct 16, 2009 | 12:11 PM
titaneum_grey's Avatar
Grey Boy
the stability control on/off switch introduses a ground to the system, if I'm not mistaken. Is it posible you could have nicked a wire or have one rubbing through the insolation somewhere around where you did your mod instalations?
Old Oct 17, 2009 | 01:55 PM
markav33's Avatar
mark-d-markos
im havng the same problem as shnka but i didnt make any mods for the problem, got my car back after a second motor replacement and the traction light came on after a few mles. i called the dealer and they said yea we noticed that problem but theres no way we can prove it wasnt happening before the swap. so i been driving since but wnters coming and i have slide sideways gon around corners a couple times so i would like some help f you fix your prob too
Old Oct 18, 2009 | 02:27 PM
shinka911's Avatar
yeah you have to ground the thermostat for the cooling mod, but i have checked it and it is making good connection. I don't believe any wires good have got cut its a pretty simple install.
Old Oct 18, 2009 | 07:45 PM
Symbioticgenius's Avatar
You Dumbass!!!
did you change your wheels recently?
Old Oct 18, 2009 | 08:45 PM
Lead foot doh!
umm... let me think ... we have had this problem before.
Old Oct 18, 2009 | 08:50 PM
ZachLegend's Avatar
i have this same problem right now. my speed sensor connector is broken. anyone know where i can get one for cheap?
Old Oct 19, 2009 | 12:28 PM
shinka911's Avatar
Nope stock wheels too. As much as I want to fix this problem, it has been a little fun never having traction control. Defently with the turbo and dropping temps
Old Oct 19, 2009 | 06:50 PM
markav33's Avatar
mark-d-markos
wheel speed sensors ? this will scew up the traction ?
Old Oct 20, 2009 | 09:20 AM
shinka911's Avatar
Yeah idk how to check them.
Old Oct 24, 2009 | 12:15 AM
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
ya i had this happen once after tires rotated. wheel speed sensors, if your able to get a hand behind the wheel and this goes for all of them look for the wire going into a connector. should be 4 of them, 1 for each wheel. start with the fronts they are easy to spot and should give you an idea how to get to the rears. its real easy
Old Oct 27, 2009 | 01:53 PM
shinka911's Avatar
So i figured it out, its a voltage problem for me. When all the cooling fans kick on at idle the voltage is dropping to low witch is turning the traction control off. so I either need a good optima or a better alternator.
