heat works some of the time?
Old Oct 3, 2009 | 02:03 AM
vglnte1's Avatar
seems the heat now will not kick on, but sometimes does. No matter how much I screw with the controls, it will only get hot when it wants. anyone experience this? could it be the controls, or something mechanical?
Old Oct 3, 2009 | 02:08 AM
cjkim's Avatar
^noob
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Old Oct 3, 2009 | 07:52 AM
rotarykillz's Avatar
Rotary Freak
Hold the Power + right SCAN UP button on the radio and it will display your Temp Level between 1-13....you'll probably find that it gets stuck on LOW temp (1-5) and will not get any higher. I can get mine to move, but plan on doing the DIY soon.
Old Oct 5, 2009 | 04:29 PM
vglnte1's Avatar
ok, so ive noticed this will be on 0 or 16, but how do I change it once it shows me the number? every button I push does nothing
Old Oct 5, 2009 | 04:34 PM
bose's Avatar
Reginald P. Billingsly
Follow the DIY, it is a little time consuming but is a life saver. Mine did this too, but after the fix it works perfectly.
Skyl3r
Dec 2, 2019 04:51 PM
thewatcher101
Jul 27, 2015 09:44 PM
dbarber
Jul 25, 2015 01:34 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
