clutch problem???
Old Oct 2, 2009 | 07:50 PM
jtabraham's Avatar
clutch problem???
Hey guys,
I think this is a clutch problem but not sure.
When i am idling the car makes a noise.
But when i push the clutch down, it sounds smooth.
Do you think i need a new clutch
or what could it be?
Old Oct 2, 2009 | 07:52 PM
dozer's Avatar
on his 3rd rx8
youre fine, it happens to all of us...its just the throw out bearing
Old Oct 3, 2009 | 12:23 AM
no, no, no.
search gear rollover.. wtf
Old Oct 3, 2009 | 03:20 AM
Jon316G's Avatar
Grasshopper
Originally Posted by swoope
no, no, no.
+1
The throw-out bearing is in use WHEN you press the clutch pedal in.
So if it was a bad throw-out bearing, the sound would get worse as you press the pedal in.
Old Oct 3, 2009 | 11:11 AM
jtabraham's Avatar
so i dont have to worry about changing anything. right?
Old Oct 3, 2009 | 11:43 AM
Huey52's Avatar
Registered Zoom Zoomer
Many performance transmissions, ours included, have gear tooth tolerances that are purposely designed wide to alleviate gear-to-gear friction/drag. The compromise-downside is some chatter noise at idle in neutral with the clutch engaged.
The right transmission fluid will often reduce this "gear rollover" noise issue, e.g. Redline MT-90.
btw: general info - we share transmissions with the MX-5 Miata.
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
