Rx8 RPM Cutoff limit to 8500 i can increase?
Old Sep 30, 2009 | 11:12 AM
KOF's Avatar
KOF
Question Rx8 RPM Cutoff limit to 8500 i can increase?
Hay i can increase RPM Cutoff limit 8500 to 9500 i have Mazda Rx8 Type S Japanese 6 Forwarded manual.
Old Sep 30, 2009 | 11:24 AM
Huey52's Avatar
Registered Zoom Zoomer
You can to 9300 with an accessport tuner and the stage 1 performance map, or MazdaManiac maps.
File Type: pdf
Old Sep 30, 2009 | 03:08 PM
KOF's Avatar
KOF
COBB TUNING AccessPORT work on Japanies, 6 Speed, 2005 Models?
Thanks for reply
Old Sep 30, 2009 | 03:50 PM
Brettus's Avatar
Boosted Kiwi
Hymee's protuner will definately do it and will remove the speed limiter as well .
I have JDM 6 speed . I don't understand why your car would be limited to 8500 though . All 6 speeds ,JDM or otherwise, are set at 9000rpm
Old Sep 30, 2009 | 06:07 PM
Increaseing the cut off will do nothing on a stock car, and FI cars peter out well before that RPM range.
Your barking up the wrong tree.
Increased RPM does not equal more power.
Old Oct 1, 2009 | 11:50 AM
Jeromie's Avatar
racing beat race reflash. almost 10000rpm.... i love it
Old Oct 1, 2009 | 12:00 PM
TheWulf's Avatar
My 8 looks like a Smurf
True, however there are other good reasons for doing it... like getting that extra bit of room without the need to shift in Autocross..
Old Oct 1, 2009 | 12:32 PM
Easy_E1's Avatar
The AccessPort is available for JDM cars. It can raise the rev limiter to what ever you want.
If you get one, get it from Mazdmaniac and you get 6 months of FREE tunes.
Old Jan 6, 2013 | 06:22 PM
Machbuster's Avatar
Extra bit of time... +500 RPM anyone? :-)
Exactly my point too. I need that extra 500rpm (no problem for the engine at all imo).
I am in a different situation - I am from Czech republic and I have a European 4Port 5 Speed version but I would really like to have that extra 500RPM before cut-off. I know it would go with no power gain in those extra rpms but that extra time to shift is what I need and also you pass 98-102-104 kmh exactly when you getting too close to that cut-off ( "magic" 100 km per hour :-) ).
I have no way to know if for example HYPERTECH MAX ENERGY would work. I know it most certainly would only work with highpower engines (6-Port). My question is different - Can you use it only to just INCREASE that limiter and keep your ECU MAP otherwise absolutely intact? Or is it complete reflash - taht would make it unusable for my 4-port... Can anyone help with some ideas. I do not want to go for COBB because my MAP is exactly what I want - very driveable, good fuel economy also... Just those RPMs needed.
ladnarf1
Apr 29, 2021 11:53 PM
madrotor
Jul 26, 2015 12:06 PM
shambo
Jul 18, 2015 02:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
