2nd gear problem
Old Sep 30, 2009 | 01:06 AM
chabinator's Avatar
2nd gear problem
rx8 2004 96k miles
it grinds when i go from 1st gear to 2nd gear at high rpm....
What should I do???
Old Sep 30, 2009 | 01:11 AM
RyansRx8's Avatar
Brettward is/has a G
Get a new transmission
Old Sep 30, 2009 | 02:03 AM
rotary boy's Avatar
myspace.com/kustal
i have the same problem... i just think the synchros are going out
Old Sep 30, 2009 | 11:22 AM
chabinator's Avatar
how much to repair the transmission..or the snchros
Old Sep 30, 2009 | 04:32 PM
corners's Avatar
An RX ate my baby
You have high enough mileage that it could be the clutch as well. Don't jump to conclusions yet.
Old Sep 30, 2009 | 05:56 PM
rplace the fluid. don't spill it. It will stink for a long time.
Old Sep 30, 2009 | 11:22 PM
chabinator's Avatar
I replaced the clutch 4 months ago......so i dont think its the clutch
Is it easy to replace the transmission fluid?
Old Oct 1, 2009 | 03:45 PM
corners's Avatar
An RX ate my baby
Sort of- you just remove the fill and drain plugs, then replace the drain plug and fill it. (Always remove the fill plug first, just in case it is stuck. Then you can still drive the car to a shop to get it fixed. If you remove the drain plug first and the filler plug is stuck then you can't drive the car)
Unfortunately there isn't much clearance under there so you need to put the car up on ramps or a lift, and you will need a gear oil pump to get it filled back up.
WranglerFan
May 31, 2022 07:51 AM
Azki23
Jun 27, 2018 03:48 PM
nowakm99
Oct 9, 2015 07:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
titaneum_grey
Sep 6, 2015 10:21 PM
