View Full Version : Clutch pedal reinstall issue
8 Maniac
09-29-2009, 09:07 PM
To make a long story short, I somehow got one of the nuts stuck to the bolt on the interior while trying to reinstall my clutch pedal after installing the support bracket for it. I'm not sure if it's cross threaded or what, but whenever I try and tighten or loosen it, the only part that actually travels is the bolt itself. I dont think this would be a problem if I could tighten it enough, but it stops a little before it's actually tight enough to use.
So I'm wondering if anyone has an idea of what I should try in order to tighten it completely or remove the nut. I've thought about trying to hold the bolt using pliers but I'm worried I might damage the threading. I've thought about getting to the other side of it but not sure exactly where the other side comes out or how to get to it. I'm assuming that I can access it on the lower part of the engine bay using jack stands but I honestly haven't taken a look yet. I'd rather not have to take it in for such a stupidly small issue, but I do need to get my car back to a drivable condition.
9krpmrx8
09-29-2009, 09:09 PM
Sounds cross threaded. But some people have had to hold the threaded stud from inside the engine bay to get the nut back on.
8 Maniac
09-29-2009, 10:52 PM
I was busy today so I didn't get to take a look, but when I looked briefly last night (in the dark with a flashlight) I couldn't really see where the bolt would be... Do I have to access it from below or can I get to it above?
9krpmrx8
09-29-2009, 10:54 PM
You can get it from above. Did you buy a new clutch, bracket, or get it welded? We were planning a mod day for this man.
8 Maniac
09-29-2009, 11:08 PM
I guess I missed that thread lol. I got the bracket from fluid. Whole pedal seemed to expensive and I trust the bracket more. Plus the bracket looks nicer.... though looks don't exactly matter when you can't see it lol.
Hopefully I can get to that bolt tomorrow and get that nut off... I miss driving lol. If it is cross threaded, I'm not sure how though... I got it to turn a few times by hand at first and I've never had cross threading once it's started to thread properly.
9krpmrx8
09-29-2009, 11:09 PM
:lol:
Yeah its probably not cross threaded.
8 Maniac
09-29-2009, 11:28 PM
I just went to check and I'm not too sure you can reach it from above... you'd have to be able to reach around and under the brake cylinder.
8 Maniac
09-30-2009, 08:59 AM
Anyone else have some input?
Huey52
09-30-2009, 09:13 AM
Most likely cross threaded. With the FluidMS clutch pedal bracket affixed the base material is thicker and you have to exert more force than without and in turn there's a good chance to scrape the firewall stud threads. Swap the nuts and try to fix the thread bite; that often works.
Don't forget to wedge the slave cylinder on the engine bay side to preclude it moving in and out as you reattach the pedal. I used a 2 lb hammer head wedged against the top of the strut column.
This really was a tough mod given the close confines and being inverted under the dash.
btw: also watch that you don't overly compress the starter interlock switch.
8 Maniac
09-30-2009, 11:42 AM
The issue I'm having is getting that nut off to actually try again. Is the best way to reach the engine bay side from the top? Is it just right under the brake cylinder? It's definitely been a pain even though it's fairly simple in concept... definitely ready to get this over with.
Huey52
09-30-2009, 11:51 AM
The clutch slave cylinder is immediately to the right of the master cylinder in the engine bay (outboard) when looking from front of vehicle to rear.
But of course the nuts that retain the clutch bracket are within the cabin.
Wedge the slave cylinder firmly against the firewall and this will hold it in place so you can back off the nuts from within the cabin. Backing off the nut(s) should adequately repair any cross threading, much as a dye would do.
Again, this is not easy given the now-thicker material and cramped cabin workspace. I think we were all glad to get it done (the least enjoyable mod I have done). But ultimately it is worth it for the failure-proofing.
8 Maniac
09-30-2009, 11:58 AM
I'll take a look at that then... Does the added thickness really make it more difficult? Seems like it would just require less cranking since it would be fully tightened earlier.
Huey52
09-30-2009, 12:26 PM
The thicker base material (due to the bracket) only makes it more difficult to get it fully seated onto the firewall, without scraping the studs and thereby cross threading - but you now know that. ;)
8 Maniac
09-30-2009, 01:47 PM
I apparently have no clue where I'm supposed to be looking cause I'm not seeing where I can access it from the inside of the engine bay... Where is it in relation to the brake cylinder?
Huey52
09-30-2009, 01:58 PM
The brake cylinder is the big black round thing on the driver's side firewall (contains a big diaphram to hydraulically push the fluid to all four wheels), which has the brake fluid reservoir attached. Immediately to its right (outboard), connected by a short length of braided fluid line, is the black cast iron slave cylinder. It's what the clutch pedal shaft inserts into from the cabin (thru the firewall). Since the clutch pedal is direct-mechanically linked to the slave cylinder, and only needs to disengage the clutch, there is no large diaphram as with the brakes.
9krpmrx8
09-30-2009, 02:00 PM
To the right of the brake master cylinder.
Huey52
09-30-2009, 02:10 PM
btw: you may be missing the point that the bolts onto which the clutch pedal bracket attach emanate from the clutch slave cylinder immediately on the opposing side of the firewall. With the pedal nuts removed you can slide the slave cylinder away from the firewall on the engine bay side (fluid line disconnected of course). This is why it's important to wedge the slave cylinder firmly to the firewall to maximize mechanical advantage tightening and removing the pedal nuts.
8 Maniac
09-30-2009, 02:14 PM
not sure how I missed that... but I've confirmed my problem and still not sure how to fix it...
The nut is holding so firmly onto the bolt that it's actually causing the bolt to move in and out of the firewall and cylinder. So the only way I can get it off is if I can find a way to hold the bolt still (to keep it from rotating) so I can get the nut off. I'm pretty sure the bolt was not meant to actually twist the way it. I might be able to completely remove the bolt if I loosen it completely through the firewall to the interior but I'm not sure if that's a good idea....
Huey52
09-30-2009, 02:21 PM
That may work. It's ok to grab the bolt from the engine bay side provide you can get a tool solidly on it. At this point you really should get some help tho', one in the cabin and one in the bay. You obviously really torqued it on there and cross threaded it (most likely scaped the threads when you affixed the bracket). But if you can get a hand and back off the nut all should eventually be well. Take a deep breath and don't throw in the towel.
8 Maniac
09-30-2009, 02:26 PM
Yeah, trying not to. I can at least see what's happening now... The only issue is that the bolt doesn't really travel further than a centimeter or so beyond the edge of the cylinder. I was thinking I could try and hold the bolt from inside but there's simply not enough room to do that, especially if I need to hold it and try to get the nut off at the same time.
cornholio135
09-30-2009, 02:28 PM
Here is what I would do then. first make sure that the other nut bolt is securely tightened. Loosen the crossthreaded nut which is going to turn the entire stud instead. This is ok. It will then come completely out of the slave cylinder side. Now go to the auto parts store and get another nut and bolt of the same size but about a half inch longer bolt. Then from the engine compartment screw the new bolt thru the slave cylinder into the passenger compartment. Have a friend hold a socket/wrench on the bolt head in the engine compartment while you crawl back under the dash and install the nut. Whala you're done....:ylsuper:
8 Maniac
09-30-2009, 02:31 PM
Is there any reason the current bolt would stop moving? Like I mentioned above, if I try to just tighten it, it stops going through the cylinder just after it actually extends beyond it. The only reason I'm asking that is because I'm wondering if I'd run into the same problem trying to get the new bolt through.
Razz1
09-30-2009, 02:37 PM
Can you get a third hand to help you?
It sounds like you need it.
8 Maniac
09-30-2009, 02:44 PM
I think 9k is gonna help me out. I'm honestly not sure how it got on so tight... I threaded it by hand and it was going fine for at least 5-10 cranks then it just stopped moving. I tried backing it off and that's when I realized it wasn't moving right. The nut is hardly even on the bolt which is also confusing. Hopefully a second opinion can get this damn thing finished lol.
cornholio135
09-30-2009, 02:46 PM
I just looked at the kit from Fluid/Raceroots. Looks like they send replacement bolts/nuts for the factory ones. Did you use these??
http://raceroots.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/d/s/dscf0011_1.jpg
see how they are installed on their complete clutch pedal assembly
http://raceroots.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/1/_/1_2.jpg
8 Maniac
09-30-2009, 02:54 PM
Those are actually just for support during the install of the bracket. They only hold it in place as a guide for the drilling etc. I dropped the original nut that was on the car and used one of the one's included with the kit. I'm actually wondering if it was the wrong size, though I compared them and it looks like they used the same size. I have some other nuts the same size that I can use if that one nut is the problem, though I still dont think that's the issue.
cornholio135
09-30-2009, 03:16 PM
Aha! the nut you used probably was not the right size... thread sizes are hard to eyeball...try my idea of just loosening the enitire nut/bolt and replace both...do not worry should be an easy fix... I know after I got done fixing mine I had briuses on my sides from crawling back and forth under the dash... If Scott (9k) is going to help you are in good hands... :icon_tup:
8 Maniac
09-30-2009, 03:30 PM
I've already got the bruises lol, now I'm just prolonging them. I'm pretty sure it's the same size but I could be wrong. I guess I'll figure it out. The one thing I need to be sure of (if I do end up getting a new bolt is that I get the right size for the cylinder.
cornholio135
09-30-2009, 03:40 PM
take the old one with you to the parts store and they can match it for you GL...
Huey52
09-30-2009, 03:56 PM
Bingo! They're not the same nut size/thread!!! Those bolts/nuts were only in the kit to temporarily hold the bracket in place for drilling.
OK, now you/we know what happened. It doesn't take much of a mis-thread to lock a nut on a bolt.
Get it off there "any which way you can" (thanks Clint) and then time to get a new bolt and nut. Oh well, we all learn from these types of happenings.
8 Maniac
09-30-2009, 08:10 PM
Same size nut I think, but was the wrong thread. 9k showed up to help and after a couple hours and a trip to the auto store (to get the correct nut and to get the other one off) we finally got it on. That was the biggest pain in the ass I've had with this car. Didn't get a chance to drive yet, but it does have a bit of a firmer feel. Watching a show right now, but I'm definitely taking it for a drive afterwards. I'll probably be glad in the long run, but that was definitely not a fun task.
9krpmrx8
09-30-2009, 09:21 PM
Glad I could help dude. It would have been easier earlier in the day with more light, :lol:. But its all good, we got it knocked out.
Plus i personally would not recommend the bracket. The holes didn't quit line up and made re installation a bitch. I will just weld the crap out of mine.
8 Maniac
09-30-2009, 10:42 PM
The wholes not lining up could have been my mistake or something. I'd imagine that if I had ordered the already reinforced bracket it would have been a better fit. Losing that nut was definitely my fault lol. I'm glad I did it, but it wasn't fun. Thanks again for the help!
Huey52
10-01-2009, 06:51 AM
Yep, this mod is kinda like Listerine; you do it because you know it's good for you, but it's no fun. ;)
Glad you finally got it sorted out and major cudo's to 9k for the assist. :)
