Trinet Motorsports brake rotors
Old Sep 28, 2009 | 09:50 PM
Chronisseur's Avatar
Gaijin
I've only had these on my car for a couple hundred miles, but thought I'd make a thread, as I've only seen them mentioned here once.
I replaced my stock rotors due to a lot of vibration when braking at moderate to high speeds. Apparently, the previous owner of my 8 had a lot of fun with the stopping power of the car. While researching different options for replacements, I came across Trinet Motorsports. They have an eBay store (oh no!), a fairly basic website, and a shop somewhere in Orange County, I believe. After reading positive reviews on other car forums, and seeing the relatively low prices, I decided to take the "risk" of buying these. Trinet Motorsports is not one of the more well known names in braking products, but after talking to the owner and a few members of the staff there, I felt confident that their product was legit. Some will say you get what you pay for, which is usually true. But I didn't feel like spending so much more for brake rotors that I believe are all quite similar (excluding two-piece, BBK's, etc.) I will update this thread if the brakes suddenly give out, assuming I make it out alive.
As far as I can tell, stopping power is about the same as stock. However, my assessment isn't the most accurate, because my stock rotors were shot, and I also changed my brake pads at the same time as these. What I can say is that they work just as they should, and I liked the additional flair that the slotted design provides. Whether or not it affects my braking performance, I don't know. Trinet also offers cross-drilled/slotted rotors at the same price, I believe. I didn't go that route after reading of the increased risk of cracking and other problems with those kinds of rotors.
Anyways, just thought I'd take some photos and let the RX-8 community know about one more option for brake rotors. My next step: painting those hideous brake calipers.
Attached Thumbnails Trinet Motorsports brake rotors-20090929-img_6606.jpg   Trinet Motorsports brake rotors-20090929-img_6610.jpg   Trinet Motorsports brake rotors-20090929-img_6616.jpg
Last edited by Chronisseur; Sep 28, 2009 at 10:02 PM. Reason: wanted to have photos as attachments
Old Oct 2, 2009 | 02:14 AM
Gaijin
I think it would be a shame for this thread to disappear into oblivion without a single response, so I'm going to ask everyone else: If you've changed your rotors, have you noticed any difference in stopping distance or braking feel? I imagine if they're the same size as stock, it wouldn't be too different. Next time I have to change my pads I may go with something a little more aggressive for harder initial bite, or some stainless steel brake lines.
Old Oct 2, 2009 | 12:36 PM
kersh4w's Avatar
Hit & Run Magnet
i changed my brake pads to hawk hps. that made a difference.
i cant imagine your brake rotors doing anything though. slotted rotors help when you're tracking. same with drilled. but you arent going to notice a difference unless you are really ***** to the wall on a track for 20 minutes.
the most noticeable thing you can do with a brake rotor is get a lightweight 2 piece and shed some rotating pounds per corner.
Old Nov 9, 2009 | 01:49 PM
jzamarripa's Avatar
So what is the update on the rotors? I was thinking of picking them up too because mine are totally warped and making all sorts of noise...
Old Nov 9, 2009 | 03:10 PM
justjim's Avatar
justjim
Your rotors aren't warped, your problem is in your pad selection and its the pads making the noise. Replacing the rotors without upgrading the pads will lead you back to the same place you are now. See Brake FAQ https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/brake-faq-167264/ for background.
Old May 11, 2026 | 05:46 PM
gracer7-rx7's Avatar
That is a pretty extreme failure. Makes me wonder if the bracket is slightly off forcing the caliper to clamp the rotor at a slight angle. Have you ever tried a "floating" rotor setup?
Sakebomb seems to have a nice floating rotor for the RX8 - and BBK kit.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Road Cone
Nov 6, 2015 01:52 PM
