View Full Version : Second gear grind issue must read!!!!!
fedno5 09-28-2009, 04:17 PM Hello, MY name is Jordan im new to the forums but i need to get this out there.
MY car has <32000 miles on it and my second gear synchro has gone out... its a 2004 and its out of warranty. I have read that a lot of people have had this same problem with the same year or even a little newer RX-8's... i took the time to email MAzda to suggest that they have a recall on the transmission they responded quickly and sent the request to the admins. IF UR RX-8 HAD THIS PROBLEM EMAIL MAZDA AND LET THEM KNOW AND REQUEST THE RECALL THE MORE PEOPLE DO IT THE BETTER CHANCE IT WILL HAPPEN!!!!!!!
THanks,
JOrdan
laythor 09-28-2009, 04:20 PM you're new, so i'll cut you some slack. Emailing mazda to suggest they issue a recall will do nothing. Just change out your fluid and most of the time that will fix the issue.
fedno5 09-28-2009, 04:40 PM what is the recommended fluid for the RX8 tranny?
souljamcdiddy 09-28-2009, 05:03 PM did yours not come with an owners manual?
SV650S 09-28-2009, 09:37 PM why you guys gotta beef so hard all the time! obviously they are refering to what brands are recommended and if a diff weight would suit different climates better for our car. its starting to piss me off when ppl get shit on for a simple question.
laythor 09-28-2009, 09:38 PM I personally use redline.. make sure whatever you use does not have the limited slip additives.
Lord ET 09-28-2009, 09:50 PM A lot will say redline mt90.. it's what I use and it's great.
xun4gvn4everx 09-28-2009, 09:54 PM Its the same deal as the clutch bracket. We tried for years to get them to recall this part since it is a safety hazard. Imagine cruzing at 70mph and your clutch snapping off while stuck in gear, not a good time. Till this day, obv, they still won't recall the part.
G3tR3DDY2GR3DDY 09-28-2009, 10:22 PM yea it wont do anything
i paid 1900 for my second gear to be fixed. my warranty got denied because of my midpipe.
put anything except royal purple in your trans. thats what ruined mine and it is no good for ours. Redline is in it now and it works beautifully!
then if its too bad, i have a spare trans for sale if you need one
xun4gvn4everx 09-28-2009, 10:32 PM ^Build me an 8, we have the technology. It will be called, the million part 8!!!!
krijpipudht 09-28-2009, 10:42 PM Hello, MY name is Jordan im new to the forums but i need to get this out there.
THanks,
JOrdan
Even your 8 is still under warranty, Mazda will not fix it for you.
Trust me, I have tried.
In my case, they claimed it is driver false, not their design problem.
corners 09-29-2009, 03:38 PM Mine just got fixed, same mileage as yours, under full warranty. Maybe you acted like a jerk to the service manager? Do they think you are a boy racer?
I didn't abuse mine. I even had the transmission oil changed at 12,000 miles.
Unfortunately its back in the shop today because the transmission now leaks. At least they gave me a loaner.
xun4gvn4everx 09-29-2009, 03:41 PM ^Some shops are more stingy about the warranty than others.
fedno 5: Try going to another shop and see what they say.
fedno5 09-30-2009, 12:22 AM thanks a lot everyone i appreciate all the help... btw the shop owner was really cool to me unfortunetly my warranty ended on the 24 of april this year... on the trans at least.... but i recently found out that the previous owner of my car had gotten a fidelity extended warranty( found this out yesterday)... they are covering all the repairs and giving me a loaner... when i get it all fixed ill make sure to put redline in it and i drive the car pretty conservatively i think its a design flaw with the way the schychros are set. But no worries i think ill be in good shape by next week when the car is back from the shop ill let u guys know how it went
fedno5 10-12-2009, 11:06 AM tranny is now fixed i used a fidelity extended warranty and only had to pay $100 so now it fixed with a new tranny :)
TeamRX8 10-12-2009, 08:29 PM Yeah, just change the oil, LOL :rolleyes:
nycgps 10-12-2009, 08:31 PM Even your 8 is still under warranty, Mazda will not fix it for you.
hmm, Mazda has no problem fixing my engine under warranty.
and Im sure an engine cost more than tranny
Lord ET 10-12-2009, 10:26 PM This is one of the first positive reviews I've read about the fidelis extended warranty! Maybe they only work if you don't buy them :)
fedno5 10-13-2009, 10:43 AM ^i guess so :) and the engine warranty is longer then the tranny and mine ended allready but oh well whats done is done :smoker:
irishmn8 12-02-2009, 08:58 PM my 05 is now grinding in 2nd in any kind of upper rpm shift, either spirited or regularly. i work at a ford dealership and one of the service advisers said he thinks it could be the synchro. should i see about getting it fixed/rebuilt or do you guys think it can be fixed with a trans flush?
JGR4444 12-02-2009, 09:06 PM my syncros are gone in every gear but sixth.. and you guys thought you had it bad! how much is that spare tranny goin for there getready2greddy?
