Brake Issues/Sounds
I'm getting this weird metallic creaking sound (best way I can describe it) when I brake from what I think is the rear passenger side. When I'm braking harder it doesn't do it, but when I brake softly at slower speeds I can definitely hear it. The sound slows down as the car does. I also think I can feel it on the brake pedal when it makes the sound, which occurs once per wheel rotation or something at a certain point? I also, get a squeeking sound from what appears to be the front driver side at the same time as the other sound.
Backgound: The rotors were all resurfaced and the pads were changed with Hawk Ceramics less than 500 miles ago. Also, the car the was involved in a rear end (rear driver side) big accident within the 500 miles as well.
Any and all help is welcome and needed!!
Since you've changed pads you know about the rear pad "tuning forks" that rub on the rotors when the pads are thin, so that's not it.
Due to accident it you may be significantly out of alignment. Getting it up in the air is a good start.
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
