View Full Version : Remote entry programming
241Commuter
01-10-2004, 12:24 AM
Somebody had posted the instructions for programming up the remote entries. I can't find the link anymore. Could you post them again? Thanks. - Bernie
StealthTL
01-10-2004, 01:28 AM
I'd be pleased to!
Bought a new remote opener and found the way to code it from the dealers manual - Bought a new remote opener and found the way to code it from the dealers manual -
(The door switch is the little rubber one on the jamb of the rear door, which controls the interior lights.)
Key in,
Ignition On/Off, 3 times,
Push door switch, 3times,
- Car will lock, then unlock-
Push 'Lock' on first remote, 2 times,
~ ~ ~ second ~ , 2 times,
~ ~ ~ third (new) , 2 times,
Now all 3 are accepted by the car.
S
241Commuter
01-10-2004, 01:45 AM
Thanks. That worked. The instructions that came from the ebay guy were close, but no cigar.
GT-Kid
01-10-2004, 01:31 PM
Can this be used to make one remote work for both my RX-8 and my wifes 6? I sure would like to get one of these off my keyring.
241Commuter
01-10-2004, 03:35 PM
When I first started looking at ebay I couldn't find any 8 remotes, only 6 remotes. The 2 remotes looks identical. The FCC number is the same but the model number was different. I checked with the local Mazda parts dept and they said the two were NOT interchangeable, so I waited until 8 remotes started appearing on ebay. Having repeated the Mazda party line, why don't you try it and let us know how it turns out?
There is a factor of 5 - 6 between what the dealer charges and what you can get the same damn thing for on ebay.
