Fitting a midpipe
Old Sep 25, 2009 | 12:31 PM
rx8james89's Avatar
silver rx8
Fitting a midpipe
It's took about 3 weeks for my ap midpipe to come and now that I have finally got it I want it on straight away, is it hard to do or shall I take it to a garage?
Old Sep 25, 2009 | 12:34 PM
dozer's Avatar
on his 3rd rx8
its a direct bolt up
take the cat pipe out and put that one right in its place...reuse the gaskets if you have to
Old Sep 25, 2009 | 12:38 PM
pdxhak's Avatar
Official Post Whore
The biggest issue will be getting the bolts loose and they may break. No biggie if they do because you can get replacements at your local hardware store.
Old Sep 25, 2009 | 12:49 PM
rx8james89's Avatar
silver rx8
My exhaust is a 3" and the midpipe is 2 1/2" will the gaskets still be ok?
Old Sep 25, 2009 | 12:55 PM
The biggest problem you will have is removing the bolts connecting the header to the MP; I had to go to a shop to get them cut off
Old Sep 25, 2009 | 01:19 PM
rx8james89's Avatar
silver rx8
It's probably worth waiting til tomorrow then in case I snap the bolts, ill have a look at it see if I can get them off if not then I will leave it, thanks for help anyway guys.
Old Sep 25, 2009 | 01:40 PM
gh8st's Avatar
STiMPACK
i think it's worth it just to get new bolts.. they're only pennies and better safe than sorry
Old Sep 25, 2009 | 02:20 PM
A helpful tip is to start with the top bolt on the header/mp area, if you cant get it off, theres no point in trying to get everything else off
Old Sep 25, 2009 | 02:32 PM
HockeyRX-8's Avatar
TNC
WD-40 and a breaker bar are your friends
Old Sep 25, 2009 | 02:35 PM
dude i emptied a can of liquid wrench and had a breaker bar and I like to think im pretty strong and i still couldnt get them off; they had to be torched lol
Old Sep 25, 2009 | 02:38 PM
HockeyRX-8's Avatar
TNC
must have been welded on lol
Old Sep 25, 2009 | 03:55 PM
rx8james89's Avatar
silver rx8
My exhaust was only fitted a month ago so shouldn't be that bad.
Old Sep 26, 2009 | 11:05 AM
rx8james89's Avatar
silver rx8
Right I just jacked the car up and it looks pretty simple I'm going to start it after I finish work, do I just take the cat straight off and replace it from there? also do I need new sensor or do I just screw it back on the new pipe?
Old Sep 26, 2009 | 11:21 AM
shazy's Avatar
/\ That's the 02 sensoer or wtv it is. Yes you should put it back in.
Old Sep 26, 2009 | 11:31 AM
rx8james89's Avatar
silver rx8
I've never done anything like this before so expect a post saying I've Fuc£ed my car up lol.
Old Sep 26, 2009 | 06:40 PM
RedRocket8's Avatar
PISTONS are for (|)
WD40 them and gently loosen them, best way.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
