A REAL DSC problem...
Old Sep 24, 2009 | 11:49 AM
Sean21's Avatar
Trawled the forum for hours, only to come up with the same answers to the infamous "DSC light on" problem.
In the past this has worked for me (ignition, turn wheel, etc.,) after disconnecting the battery. However, after I did a steering rack swap I put the car back together and took it for a test drive to see if everything was ok. DSC light was obviously on and after taking it for a drive, noticed the wheel wasn't on straight. DSC light had turned itself off by now.
Disconnected battery and set the steering wheel straight. Now the DSC light is on and will not go off. Tried all the reset procedures, including the ECU ones.
Any ideas??
Only thing I can think is I read something to do with the steering angle input sensor may set off the DSC light if it isn't set straight?
Thanks in advance.
Old Sep 29, 2009 | 08:48 PM
csiepka's Avatar
Any ideas??
Thanks in advance.
Sorry Sean, don't have an answer for you, I'm hoping that the problem went away, did it?
Old Sep 29, 2009 | 10:08 PM
expo1's Avatar
He's as bad as Can
BINGO !! Fix the steering issue and the light will go away. I know this from when I had an engine installed. The wheel (rack) was just a little off from dead center and the DSC light was on.
Old Sep 30, 2009 | 07:16 AM
Sean21's Avatar
Yeah that's what I thought. Had the wheel off a couple of times to try a couple of different positions off-centre, still no luck.
I haven't had the tracking done since the new rack, so I think once I get that done I can see if the wheel was off true-centre even with it straight.
I hope that will solve it, otherwise I'm all out of ideas.
Thanks for the input nonetheless.
Old Sep 30, 2009 | 07:22 AM
expo1's Avatar
He's as bad as Can
How did you attempt to fix the off centre issue? Via the tie rods or by taking off the steering wheel?
Old Sep 30, 2009 | 07:27 AM
Sean21's Avatar
By the steering wheel.
tbiggybig
35
Jul 14, 2022 06:14 PM
D13
Oct 1, 2015 07:55 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
Trekk
12
Sep 25, 2015 03:08 PM
