Cooling diagram
Old Sep 23, 2009 | 08:31 PM
tmak26b's Avatar
Cooling diagram
Out of curiosity, anyone have a picture of the cooling system diagram? I would like to see the path of all the little coolant hoses.
THanks
Old Sep 23, 2009 | 08:34 PM
mrslysly's Avatar
07 Rx8
Search for the FSM (Factory Service Manual). Plenty of places online to get it. And then not only do you have the coolant flow diagram but also every other diagram you could ever want for your car.
Actually, I'm sure the thread on this forum pointing to a site hosting the FSM still exists. Search feature. GO GO GO!
edit: Here ya go. http://www.hi-impact.org/ryang/modif...8_manuals.html
Old Sep 24, 2009 | 02:29 PM
Nubo's Avatar
Lubricious
It's not a very complicated path. Basicall a loop between the condenser, compressor, and evaporator, with a couple of valves for adding/measuring refrigerant.
Old Sep 24, 2009 | 03:52 PM
ASH8's Avatar
Super Moderator
I think he means the Cooling System not Air Conditioner Cooling?
Old Sep 25, 2009 | 12:15 AM
tmak26b's Avatar
The cooling system. THje shop manual is useless, it gives you the diagram of the big hoses. I am interested in the heater hoses and the little hoses.
Old Feb 12, 2010 | 11:55 PM
Macius8's Avatar
bump anyone have such a diagram?
Old Feb 15, 2010 | 07:23 AM
There are a lot of entry/exit breaks in the system
one heater connection on lower left side of rear housing and then the metal tube line that runs on the firewall behind the engine and the other line connects near the t-stat (attachment #3)
one throttle body connection near the t-stat and the other connection point is on the top right side of the rear housing behind the intake manifold (hose runs underneath the UIM - attachment #5)
the rest is pretty straightforward, but feel free to ask if you have any questions
Attached Thumbnails Cooling diagram-rx8cooling1.gif   Cooling diagram-rx8cooling2.gif   Cooling diagram-rx8heater1.gif   Cooling diagram-rx8heater2.gif   Cooling diagram-2f06431_1000.gif
Old Sep 5, 2010 | 04:53 AM
Gauge's Avatar
Not Jeff Gordon
Anyone know where to get a replacement heater hose ? Ive searched and nothing. Its the 61-213 on the third diagram I believe. Im uninstalling my racing beat gauges and the water temp sensor adapter is there.
Old Sep 5, 2010 | 05:07 AM
ASH8's Avatar
Super Moderator
FE01-61-213 Hose $5.90
http://www.trademotion.com/partlocat...&siteid=214264
Old Sep 5, 2010 | 09:25 PM
Gauge's Avatar
Not Jeff Gordon
Thank you kindly
Old Jan 27, 2012 | 12:51 PM
ooobigfire's Avatar
Regarding the hose that runs under the UIM. Does anyone have a part number for that? And where I could get one I know this is an old thread just trying to figure out where my leak is and is seems to be coming from underneath the UIM.
Old Jan 27, 2012 | 01:03 PM
Highway8's Avatar
Registered RX8 Nut
Bolk heater hose of the same diameter and length will work fine.
Old Jan 27, 2012 | 01:37 PM
ooobigfire's Avatar
Good to know! Hopefully its that hose and not something worse :/ the smell is terrible it doesn't leak much but it steams a bit (especially after spirited driving) and when I've got the vent on it gets all in the car. The coolent temps haven't been effected at all though.
Old Aug 24, 2012 | 12:33 AM
Bumping for a question.
What purpose do the two little hoses on the rear of the coolant expansion tank serve? There is one that feed below the Tstat and one that feeds above. Some type of bypass? Does the larger of the two allow coolant to pass through to the engine when the thermostat is closed?
Old Aug 24, 2012 | 01:32 PM
Anyone?
Old Aug 24, 2012 | 08:19 PM
olddragger's Avatar
i think it is for re circulation of the coolant?. i mean some cars have just an expansion tank, some have the tank that can also recirculate the coolant to the engine.
Old Feb 4, 2021 | 01:38 AM
motodenta's Avatar
Lightbulb Schematic diagram
The other day I was doing some studying and 've made these comprehensive schematicd diagrams, I think it's nice to share them with others.
End plate
Thermostat housing
Cooling schematic diagram
Supplementary links:
Old Feb 4, 2021 | 12:17 PM
never saw 9k’s question from 8 or 9 years ago, but for future reference they’re for allowing air to escape out of the coolant system into the air chamber in the expansion tank. That’s the main purpose of the tank; to separate air from the system and indicate the coolant level to maintain it that way.
Old Feb 11, 2021 | 01:34 PM
motodenta's Avatar
Almost forget to post the right handed version
Old Feb 12, 2021 | 10:52 PM
isn’t it essentially the same thing?
Old Feb 13, 2021 | 04:43 AM
motodenta's Avatar
Essentially and technically yes! Apart from the heater core sits on the other side of the dashboard, firewall connection, a few heater core hoses, water direction on toper metal pipe.....
Having "Restricting Valve Orifice" is hit and miss by the year of production and the imported market as far I understand.
Old Dec 29, 2024 | 06:51 AM
RotaryR1d3r's Avatar
End plate
Thermostat housing
https://flic.kr/p/2kywGqy
https://flic.kr/p/2kyw2RD
https://flic.kr/p/2kyw2S5
This is so awesome. You deserve a rotary that never needs a rebuild.
Old Jan 21, 2026 | 01:41 PM
viviogs's Avatar
you made my day, thanks for those very clear images
Conduct
Oct 7, 2020 06:57 PM
hazemate
Oct 23, 2015 04:43 AM
Shadowrx
May 6, 2014 09:59 PM
jossef
27
May 23, 2007 05:20 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
