Hazard light fuse keep blowing
Old Sep 23, 2009 | 12:04 AM
csl's Avatar
csl
Need help to get a PDF copy of wiring diagram as my hazard light fuse keep blowing up.
Situation:
1. When use hazard light, relay buzz.
2. signal to right ok
3. signal to left, hazard light fuse blow. (bulb still ok)
What had I tried:
1. Remove head lights and signal bulbs, situation still the same.
2. Remove battery, not trigger the signal or hazard light, found continuity on the left hand side side marker bulb connector.
So I believe there is at least 1 spot that is short circuit. Hope anyone can pm me a link for the wiring diagram (tried google and yahoo search). I need to know the wiring routing. Thanks.
Old Sep 23, 2009 | 12:06 AM
Jon316G's Avatar
Grasshopper
The entire service manual can be downloaded here:
http://isomerica.net/~fluffy/Ren/RX8%20FSM/
I'll take a glance over the circuit and see if I can help out.
Old Sep 23, 2009 | 12:08 AM
csl's Avatar
csl
Thanks you very much
Old Sep 23, 2009 | 12:15 AM
Jon316G's Avatar
Grasshopper
You sure it was a relay buzzing? Not seeing one in the circuit.
And its a pretty simple circuit with nothing between the fuse and the flash control module.
Might want to check continuity in the wiring to the module.
Old Sep 23, 2009 | 12:17 AM
Jon316G's Avatar
Grasshopper
In the 'BODY' manual on page 212 shows how to inspect the flasher module and which terminal is connected to the fuse.
WranglerFan
Aug 21, 2022 01:29 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
just1jack
Sep 9, 2015 04:45 PM
