View Full Version : Quick cargo net question...
G8rboy
01-09-2004, 03:06 PM
I was thinking about getting one to hold a few loose items in the trunk, but wanted to make sure where it installed- is it close to the trunk opening, or more forward against the back of the back seats? If the latter, I don't see it's usefullness with that big spare tire in the way.
Anybody have a pic handy of it installed? (I did some searches, and learned of the installation tips, but no pics)...
-Sean
Wingnut
01-09-2004, 03:23 PM
Yes, it is tight against the trunk entrance lip, not the rear of the rear seatbacks. Overall I like having it, however, I do occasionally snag a piece of luggage on it and have to back it out and reinsert. I keep a quart of oil and a few items in it that would otherwise bounce around a little bit.
WN
brothervoodoo
01-09-2004, 03:24 PM
It's by the trunk opening. I will see about getting a pic if possible.
8_wannabe
It goes at the very rear of the trunk, right at the opening. Getting things in and out is way easy. You said you found prior threads on install; I would reiterate that using a hammer to gently tap in the four anchors worked very well. Otherwise, getting the screws to start in was virtually impossible for many people.
G8rboy
01-09-2004, 03:25 PM
WN
Perfect- I'll order it then... thanks for the quick reply!
-Sean
i3man
01-09-2004, 06:24 PM
I'm surprised that nobody has tried to make their own cargo net yet.
Speed-ER doc
01-10-2004, 04:16 AM
My golf bag ALWAYS snags on the darn thing. I'll probably remove mine.
G8rboy
01-13-2004, 06:09 PM
Thanks-- I received the cargo net from Trussville today. I followed the 'tap it in' method rather than widening the holes for the bottom, with one small twist. I put a little spit on the rubber 'sleeves' to lube them and used a rubber mallet to do the tapping- took about 2 minutes to do the whole thing. Now my car care crap isn't bouncing around the trunk : )
-Sean
